Home > Puma (Tdci) > What sealant?
roadracingtog
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
What sealant?
What type, brand of sealant would you re commend to fix water leaks?
Post #106627 13th Dec 2011 1:06pm
Zagato
Dum Dum (general areas) & Sealing Compound (windscreens, capping's etc) from Frosts.co.uk Thumbs Up
If you can't get hold of Dum Dum just get the window sealing compound it's the same stuff just slightly runnier/tackier. I squirted out 4 lines of the sealant and left them for 5 days they where less tacky and more manageable then for the areas you need to just thumb in Wink
Here http://www.frost.co.uk/automotive-windscre...ealer.html
Many of the silicon sealants are like a very strong glue as windscreens on modern cars are a structural part and therefore need cementing in properly - Defenders don't need this of course and you save a lot of hassle for future maintenance if you use the right stuff. Don't use bathroom sealants etc they are not designed for the job and some have an acidic content to prevent mould which will damage your paint etc long term. Best to just use the right stuff in the first place Thumbs Up
Post #106631 13th Dec 2011 1:12pm
BigMike
rtv
Post #106647 13th Dec 2011 1:55pm
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Just had most of the front end of mine (from windscreen areas) RTV'd - working very well. Defender 110XS SW gone... now VW California 180 4 Motion.
Post #106654 13th Dec 2011 2:14pm
MartinK
Hmmm. I bought Sikaflex 221 for mine. Had intended to do the cappings and anything else...but not needed to as yet...
Is sika 221 a bad product??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #106747 13th Dec 2011 8:38pm
jst
Sikaflex or RTV or any of the loctite brand. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #106760 13th Dec 2011 8:51pm
roadracingtog
Thanks guys, I'm slowly identifying the sources of the leaks. I've removed most of the interior trim from the rear load space on the nearside. 2 small gaps between rear door seal and bodywork. One at the junction of the capping and the other at the junction of the seal and the roof. Easy fixed I reckon. The third is proving a bit more difficult and this is the one that concerns me most. It appears to be water thrown up by the rear wheel and making it's way between a joint somewhere in the area of the wheel box and rear seat box/door slam. I'm waiting on the word of LR for the main dealer to proceed with the work. I guess they'll get a closer look on Monday when it's in for a new rear screen and oil leak from the transfer box. Rolling Eyes
Post #106788 13th Dec 2011 10:01pm
Zagato
There are gaps quite often around the seat box area, easy fix to plug the hole Thumbs Up
Post #107385 14th Dec 2011 8:08am
Caterham
what about where the angle bit is for the fuel filler.....mine leaks round there.
Post #209450 8th Feb 2013 10:29am
