![]() | Home > Maintenance & Modifications > What is your best and worst modification? |
newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351 ![]() ![]() |
Tough one cause there are so many that just make you smile like a chid on Christmas morning.
best, 12v fridge or BAS remap worst, none really. My Defender and travels |
Gunbus Member Since: 16 Mar 2015 Location: Argyll Posts: 46 ![]() ![]() ![]() |
Best mods for me so far have been upgrading lights to LED type and sound proofing.
Worst has been installing foam sound proofing then feeling like a tool when I had to strip it out to install better stuff! ![]() |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 ![]() ![]() |
Best
300Tdi coolant alarm - reassuring Turbo gauge - I use it all the time to see how much I'm asking of the engine Average 1.2 transfer box - the motorway crusing is great, but A roads not so much. An overdrive might be better, although this mod is cost effective Worst Polybushes - Wear just as quick as cheap rubber ones. Only genuine these days |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648 ![]() ![]() |
To save me time, would you have the link to how to do this please! Many thanks! ![]() |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 536 ![]() ![]() ![]() |
I've a few to add to the list:
Best mods: Mud stuff overhead consol. This is great for hats, gloves, hi viz etc. Also good as it hides the top of the windscreen to roof join which is hard to retrim yourself. Om 606 engine swap. Or any engine swap. Anything will be better to drive than a 2.25 petrol. Automatic gearbox. Totally transforms your Landy, no more achy legs, you need to like auto's though. Probably best when fitted to a V8, td5, M57 or Om 606. Led rear brake and tail lights. No more intermittent lights. TDI indicators. These are better than the earlier type as they have a sealed lens unit with a modern style twist out holder, accessed from the back, they're just better. Except the brake lights, see above. Will need larger holes to fit. Rear disc conversion. Saves adjusting shoes. They don't work any better though. Ministry of defender puma style dash. Great upgrade for the multi - piece, pre - puma models. Neat, more modern style, no rattles. Solidly made in the UK. Sound proofing. Even a floor mat will be better than nothing. Preferably followed by carpet. Polybush kit. Takes out all the slack and wobblyness. So do new bushes, probably. Crystal lenses. They look nice and work better than the older type. Swing away spare wheel carrier. I fitted a genuine one, which is great and takes the weight off the the back door. Nas rear step, nice and neat to hold the tow ball. Custom exhaust with lifetime guarantee. Just perfect, fit and forget. Early series doors and tops. The sliding windows are about 500 times better than wind up windows on any car I've ever been in. They don't let in the rain whilst driving along and let in the perfect amount of ventilation. They can also be adjusted in a millisecond. Worst mods:. Series doors and tops, although I like the operation of the sliding windows, see above, I don't like the look of them, they really date a defender and the fit is appalling. They're drafty and leak, just like the later ones. Twin washers jets. Twice the amount of water but half the pressure. Probably better with twin washer pumps. 1.2 ratio transfer box on a 200 tdi 110. It's too high geared for the engine power. I swapped it back to a 1.4 and it was faster. High 5th gear on an Lt77 V8. Pointless. Too high, only any good down hill. All of the above have been tried and tested on my own land rovers. |
nick.bw Member Since: 26 Oct 2020 Location: Essex Posts: 76 ![]() ![]() ![]() |
That link would be handy |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
Best -
LED lighting, better performing and reliability is significantly better. MTR’s, I am a BFG fan, they look nice but the important thing is the last a long time and perform exceptionally well. (At a price, but you get what you pay for). Nak DAB, It just works well and is resilient for greenlane use. Audio Upgrades, Big impact, depends much on what you fit and where to taste. Worst - Not much that I can think of, but don’t go drilling holes all over the place without lots of prior planning, templates and measure twice before any cutting or drilling. I have no regrets because of this, but it would be very easy to achieve this if you don’t follow this advice and you need to be very wary of mods where there is no going back. Some mods you can’t really replace or repair, or could be very costly, so is best to carefully consider these mods that need a lot of fitting and modding, for example a 2din audio install, drilling A pillar and various other things of that nature. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3820 ![]() ![]() |
A few...
Safest: LED lights (not headlamps yet) as not sure how snow etc affect them but the side lights / indicators are SO much brighter than standard. My most favourite Startech steering wheel, transforms the drive, lovely to hold just makes the car feel better every time you drive it. Useful double din radio with DAB, camera, brilliant for reversing on your own to a trailer, car play / waze is ace. Able to read out texts etc. Coolness LED light bar - no other reason except it turn night into day in the dark lanes. There are so many more I could list pages... Worst modification.... Don't have one, but I do always get annoyed at how the double din fits no matter how many times I try to redo it. Just the top edges where the clock is... the radio with all the amp cables etc its just too much stuff in a small gap ![]() [/i][/u] |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5938 ![]() ![]() ![]() |
Good mods:
Night heater Heated seats Headlight wiring upgrades and clear lenses One piece rear side windows - no leaks/rattles Front ATB/Centre ATB LED rear brake lights Worse: Disco transfer case in a 110 used for towing Mud stuff seat risers - raised the seat just too high for my liking 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
C90 Member Since: 19 Nov 2024 Location: East Posts: 46 ![]() ![]() |
Best ROI mod for 100 sterling...
I just swapped out my old Puma XS cubby (the one with the basic vinyl-covered plywood lid) for a Britpart 'Chubby'. It’s got a padded lid and sits higher, so now it actually works as an armrest as well. This is a total game changer for comfort being able to kick back in armchair mode on the motorway! Simple and cheap but very very effective! |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2264 ![]() ![]() |
For those from Yorkshire , a cheaper option would be putting a small cushion on top of the existing cubby
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 236 ![]() ![]() |
Moving the handbrake lever to next to the seat so I now have room for my left leg is my current favourite mod.
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1238 ![]() ![]() ![]() |
Best by a long way: Range Rover seats
![]() Click image to enlarge Every other mods falls into the good category, 1.2 transfer box, swapping out rear safari windows for 88" sides. Only one that's neither here nor there is the 285x75R16s, running a 33" tyre and 1.2 box makes first very very tall but when I got a set of new 285s for £450 and a set of 4 was going to be north of £1200 I can live with that. Worst: using Buzzweld to repaint various bits of the chassis. It wasn't cheap and it's been utter crap. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
