Home > My Defender > DIY Crash repair diary
tobias6
United Kingdom 2010 Defender 90 Puma 2.4 HT Tamar Blue
Hello all,
I am going to be documenting the process of repairing my Defender after a motorway crash in February that left it looking pretty worse for wear.
For context, I was on the motorway in Belgium a few weeks ago on the way to The Netherlands and while cornering on a junction the whole Landy lost grip and span 180 degrees, hit first the front left corner on the concrete barrier and bounced off and hit the back left corner on the same barrier.
My options were:
-Pay a bodyshop to do the repairs (out of the question due the amount of work needed)
-Claim on my insurance (not a good option as my insurance is already through the roof after having a van stolen and my motorbike crashed into while parked.. both my fault according to my insurance!)
-Repair it myself.. I have a workshop space for my business, tools, and I know my way around the Landy. And I will secretly enjoy the project.
The damage
In a nutshell,
At the back end - tub caved in, rear crossmember bent, lights number plate and arch flare need replacing. Tailgate and side panel intact. Chassis not visibly affected forward of crossmember.
At the front end. Front looks better at a glance, but this is where the chassis actually did take a lot of impact. Chassis end (where meets bumper) is now 10mm or so closer to its O/S counterpart, will try to bend back but might have to live with it if it doesn't cause any issues. Front bumper ruined, front grille ans N/S light surround cracked, A bar bent, wing panels all damaged. Grille frame, radiator, and all lighting unscathed. Drivetrain, suspension and steering all fine.
Thanks for reading so far. I will try to update this in case anyone is interested or in a similar pickle themselves and gets inspired to have a crack at it. Like most of us in the LR community I am a complete DIYer when it comes to cars but I am lucky to have a drive-in workspace and a lot of tools!
Tobias 2010 90 HT
Post #1064266 30th Mar 2025 10:44pm
tobias6
Part 1: New Wing
Decided to start with the easier end of the car to fix. A theoretically simple job of replacing the whole wing assembly. The tricky part is that I have to paint it.
I ordered a full aluminium wing assembly from Stamp Panel for £400. It came in a very sturdy box but still got a couple of dents in transit somehow. So first job was to fix these.
My photo journal is off to a bad start as I did not take any photos of this but i just gave them a few taps from behind with a panel hammer until they were flat, and then keyed the surface to 120 grit and added some Dolphin Glaze filler to smooth out the hammer marks:
Next I sanded the filler and keyed the factory etch primer to 400 grit
Then I applied three coats of rattlecan high build primer to the two areas where I had done repairs and any areas that were I would be likely to break though when sanding (edges and joins). Everything then sanded to 800 grit:
Next step - base coat. This is where it becomes new ground for me, I haven't used a HVLP gun in at least 5 years, but thankfully a friend had a good quality one, and a spray booth for me to borrow. The paint was easy to mix, 1:1 ratio with thinners. I did one coat and wet sanded it to 1500 grit:
And then 2 more coats:
Following the base coat, I applied 3 coats of 2k clearcoat, again with the HVLP gun.
I didn't get the best finish, but as a complete novice I didn't get any runs and noticeable defects so I'm chuffed, and the finish should be improved with a cut and polish, which I did next.
Wet sanded to 1500 and then 3000 grit, thoughtoughly cleaned, and then machine polished with a polishing compound:
In between coats of paint and lacquer I stripped down the front end and removed the damaged wing.
Cleaned off all the mud and wrapped some pallet wrap until I get time to install the new wing.
Thanks for reading
Part 1 costs:
New wing £400 - Stamp Panel Ltd.
Primer, paint, clearcoat £118 - Advanced Paints
Part 1 total costs: £518
Project total costs: £518 2010 90 HT
Post #1064268 30th Mar 2025 11:50pm
Ianh
Nice work on the wing... you do know you will now have to spray the rest of the vehicle to match the nice new wing paint Very Happy
Post #1064270 31st Mar 2025 12:41am
tobias6
Ha! That would be nice, always liked Epsom green… but I’m hoping I can get away with machine polishing the rest of the car. I did a couple of spots and it comes up very close to the new paint 2010 90 HT
Post #1064273 31st Mar 2025 6:52am
mini Anaconda
Looking forward to seeing more updates, great work so far. BORG - Bucks & Oxon 4x4 Response Group
Post #1064305 31st Mar 2025 2:00pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Great effort. Thumbs Up
I'll be following with interest 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #1064323 31st Mar 2025 5:17pm
Procta
cracking paint job that, shame about the crash, I wonder if the landy hit a patch of oil for it to kick its backend out like that. My old TDi was dodgy in the wet, due the very cheap tyres that was tossed on it from the dealers. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #1064325 31st Mar 2025 6:18pm
I must admit that I had not heard of Stamp Panel before this thread, but that looks a pretty good part at a sensible price. Do you know if they make the panels themselves?
Post #1064330 31st Mar 2025 6:57pm
L110CDL
Thank you for posting your repair work and costs, i will be following for sure Thumbs Up Clayton.
Keeper.
Post #1064349 31st Mar 2025 9:13pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Nice work, looking forward to the next installment...
Post #1064356 31st Mar 2025 9:39pm
Ianh
Stamp panel is the ebay shop for SP-4x4 ( SP Panels ) https://www.sp-4x4.com/ who I expect you have heard of .
Post #1064362 1st Apr 2025 12:21am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Cracking job! Thumbs Up
Jim
Post #1064366 1st Apr 2025 5:27am
Yes indeed, and I think I now realise what the letters "SP" stand for! Thank you for this info, and I now understand the quality of the part. Thumbs Up
Post #1064390 1st Apr 2025 9:08am
1964_cooper
Thanks for sharing! The wing looks great and I look forward to more updates 👍🏻 Sam
2003 TD5 90 CSW (SOLD)
2008 TDCI 110 CSW (SOLD)
1990 V8 110 CSW (SOLD)
1999 TD5 90 (SOLD)
1995 300Tdi 90 CSW (SOLD)
1955 86” Series 1
1950 80” Series 1
1989 Tdi Discovery 1 3 Door
2010 2.4 Puma 110 USW XS
Post #1065810 18th Apr 2025 9:14pm
