Home > Technical > What’s this noise?
Diesel Power
United Kingdom 1992 Defender 110 300 Tdi CSW Java Black
What’s this noise?
Is my diff about to explode?
Just started today so I’ve parked it up for now.
It seems to be coming from the rear and its worse pulling off or coasting.
Any help much appreciated.
[url] https://whyp.it/tracks/272482/noise
Post #1065301 11th Apr 2025 5:28pm
landy andy
You checked the prop ujs?
Post #1065312 11th Apr 2025 9:31pm
Roverdrive
As said above it is worth checking the prop UJs.
Chock the wheels securely and take it out of gear and handbrake off to take weight off the prop.
Hope this helps 110 CSW
Post #1065313 11th Apr 2025 9:39pm
As above, sounds like a UJ bearing has gone or very, very, dry, possibly roller bearings gone.
Regardless check the diff oil level and colour.
The rear prop UJ’s are a little more likely in my opinion to go.
How often are the UJ’s greased? WeWillWin🇬🇧🇺🇸
Post #1065314 11th Apr 2025 9:47pm
Bowbearer
United Kingdom 1985 Defender 110 200 Tdi SW Auto Baltic Blue
Take it out of difflock as well before checking.
Post #1065327 12th Apr 2025 8:12am
Diesel Power
Thanks all for the help.
On closer inspection, found this.
Not sure if this is just the UJ that’s trashed or whether I need to replace the whole prop. I was planning to upgrade to a Gywn Lewis HD one anyway.
Post #1065341 12th Apr 2025 12:01pm
Ianh
They look very dry and very rusted, I’m wondering on the condition of the splined shaft as well.
If the yokes and splined shaft are ok then a good clean with a wire brush, replacement UJ’s, a paint and a good grease should refurbish ok.
That lot will take a while if it’s your first time and you will need correct tools, ie, good circlip pliers, large vice or press, correct size sockets grease gun etc. And you vehicle will be off road while you do it.
So if you don’t have a vice etc it may be more cost effective buying new props ( I’m assuming the other one has not had grease as well so will be in a similar condition soon.) and Gwyn Lewis HD ones are very good. You can also change the props over in an hour or so , therefore vehicle will be back on road quickly. If you were thinking of going that route anyway now is the time to do it.
Ps don’t delay, else you could damage rear diff components.
Post #1065344 12th Apr 2025 12:38pm
Diesel Power
Thanks for the advice.
I wanted to swap both props anyway so now’s the time.
Does anyone know the part number for a 1992 200 TDI? I’ve looked at GKN rear props and some websites have them for around £100 and others list a genuine one at upwards of £800.
I think the GL HD ones are worth investing in as a fit once and forget.
Post #1065349 12th Apr 2025 3:36pm
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
The GL ones aren’t fit and forget.
They will need a regular squirt of grease twice a year, preferably more, then they will last for ages, if your defender isn’t lifted.
When you order it order the socket extension ,as it saves loads of time when you fit them. 2002 td5 90 county hardtop
Post #1065350 12th Apr 2025 4:03pm
Standard props are Hardy Spicer I think, whatever you do have will need regreasing as mentioned, I do mine every 3 months now.
If you do just replace the UJ the GKN is the way to go, but again as mentioned depends if there is damage, if the bearing cup is in-tact you should be okay, but if the roller bearings are gone, and there is damage to the bearing cup and the housing then there will be quite some off balance, better off getting a new prop.
Standard props are fine for the majority of peoples uses but those UJ’s are bone dry.
Of course, another thing unless you DIY service is ignored commonly by garages.
Things like UJ and Prop Slider greasing doesn’t get done, nor brake fluid, nor does electronics sensor cleaning if applicable.
So a lot of people think this is done with servicing and it isn’t, and many won’t tell you either.
Plus they’ll use lower spec oils etc, so worth bearing in mind.
If you want a quick fix and less work, I’d look at a Hardy Spicer stahdard Prop, grease it up nicely and fit.
If you have the time, and feel like it, plus the condition of the existing prop is usable then you can replace the UJ’s, but they can be a bit of a trial as mentioned already you’ll need a large vice, circlip pliers etc, the old ones can be a pain to get out.
The choices are yours really, oh and if you need to use it you can run in 2wd with diff locked if you need to for a while if that helps, then you can do one prop at a time.
In the long run though you’ll need to keep them greased, either DIY or ask for it to be done.
The cab actually be quite dangerous if that failed at speed, so good job you noticed and stopped driving it right away now. WeWillWin🇬🇧🇺🇸
Post #1065355 12th Apr 2025 6:11pm
Retroanaconda
The yoke is knackered - you need a new prop.
Post #1065356 12th Apr 2025 6:20pm
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
As Retro said - the yoke itself has been eaten, so not serviceable. You need a new prop. Just zoom in your own photo where I have circled in red the evidence…
/Mat
Post #1065369 13th Apr 2025 4:42am
Yeah, that’s a new Prop needed. I was using phone so didn’t take a close look.
A good job it didn’t break free! Shocked WeWillWin🇬🇧🇺🇸
Post #1065385 13th Apr 2025 9:37am
Mo Murphy
All for the want of a bit of maintenance !
50 Shades of Pennine Grey
Post #1065388 13th Apr 2025 9:56am
Oldowner
I expect the rest of the vehicle is in similar condition!!!
Post #1065446 14th Apr 2025 8:47am
