![]() | Home > Puma (Tdci) > Random cut out |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20746 ![]() ![]() |
VCV’s are fickle, and vary in lifespan, but if you do think it’s electrical then main power supply connections are worth checking, from ground points to main lives and battery clamps etc.
Usually these things get loose due to vibration over time, Relays loose in their sockets can be an issue, or slight build up of corrosion on the sockets / pins. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 687 ![]() ![]() |
As above.. check the supply and ground to the power relays and ecu..
A waggle test of looms whilst running.and the same on the crankshaft sensor wiring.. Fault codes or pending codes worth checking , and possibly better still if if the tool is capable of the landrover specific codes , rather than just generic obd.. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5866 ![]() ![]() |
Battery in remote fob???
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1984 ![]() ![]() ![]() |
Thanks chaps
I don’t thinks it’s vcv related tbh, when it’s not firing it’s like the immobiliser has kicked in? I’ve changed the crank sensor last week during my head rebuild, will check the wiring. I’ve got a Nanocom and I have no idea why’s I haven’t checked ![]() Been so involved with the rebuild common sense has gone out the window! It slipped my mind I had it 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 206 ![]() ![]() ![]() |
If it cranks, then it is not the immobilizer.
