![]() | Home > Puma (Tdci) > Another.. “Can you help me find where..” |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2163 ![]() ![]() ![]() |
You might be better recording the sound/noise to help us identify the potential cause.
As diff oil is inexpensive, and it is easy to change, I’d suggest you do that anyway given you don’t know when (if) it was last changed? Good luck ![]() |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2246 ![]() ![]() |
A few tips, Make sure you undo the fill plug first, you don’t want to drain only to find the fill plug is stuck.
Before you do, purchase some magnetic diff plugs, they are cheap. Also some hylomar blue as a sealant when replacing plugs. And do not over torque on refitting. |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 922 ![]() ![]() ![]() |
Hi
I hade a similar noise, that sounded like distant a helicopter, on my L322. At first I thought that it was the front diff but on the advice from a guy on the "Full Fat" forum I went for a drive and then temperature checked each brake caliper using a laser thermometer and found that the front drivers side caliper was partially seized. I rebuilt the caliper and no more helicopter.. Jim |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 224 ![]() ![]() ![]() |
"A whoop whoop noise coming from the driver's seat area".
Time for the driver to visit the doctor? ![]() ![]() |
