![]() | Home > Maintenance & Modifications > Chassis cleaner - dry mud/sand ? |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 918 ![]() ![]() ![]() |
You’ll have to use a hot power wash on something that dried on. 2008 2.4 110 Utility Station Wagon XS.
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1849 ![]() ![]() ![]() |
Mine was only just over a year old but was caked inside and out with Spanish red dust and mud - I left it on axle stands as high as possible, but angled down at the front, then set an oscillating garden sprinkler underneath on a timer - a couple of minutes per hour for 24 hours, this really softened the mud, then I used a Karcher on the outside and a drain snake inside.
After drying for several days I lathered it in various Dinitrols and MIL Spec cavity wax and 15 years later chassis is still superb HTH Keith |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 916 ![]() ![]() ![]() |
Hi
Do an internet search for your local truck wash. They will normally do a full chassis and underside clean for a reasonable price. You are then left with a blank canvas that allows you to assess the condition of your chassis and running gear, make repairs if necessary but most importantly treat for rust and then apply one of the many 'protective' products to help keep corrosion at bay. Jim |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20717 ![]() ![]() |
Leave it to dampen, a lot of it is where it is dry, personally I keep pressure washers away far too much damage and water pushed in where it shouldn’t.
It does take a lot of time to do a top job. Are you painting or rust proofing? WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
