![]() | Home > General & Technical (L663) > Front seat headrest removal |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1443 ![]() ![]() ![]() |
You could try this!
![]() ?si=SE1Q4nJWK-KDMNea Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
GAT Member Since: 20 Apr 2013 Location: Kent Posts: 120 ![]() ![]() |
Well who knew
![]() P400 110 in Tasman Blue. |
hmgt3 Member Since: 13 Nov 2023 Location: MCT Posts: 8 ![]() ![]() |
🤣 Looks like I’ll have to.
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
I read that the front headrests are fitted to a 'Safety restraint' system. In the event of an accident both headrest are pulled down to there lowest setting.
I'll try and find the LR document, LR claimed the front headrests are NOT removeable. Yes you can remove with a big mallet, ........ how do you reinsert them ??? BEWARE !!! pdf for you to read. https://www.lrdefender.org/front_row_seat_...-1042.html |
Thanks for that info. You are right, as per the link you posted. The back of the seat has to come off. It isn’t a simple procedure. Just confirmed it with the dealership.
