Home > General & Technical (L663) > Air suspension remote control
Crazymind
Just read an article of a test drive and the writer found a trick:
“Also found a party trick for the air suspension. You can operate it from the outside using the key! Say you want to raise the height of the car for easier loading or just want to show off that your car has air suspension. With the hazard lights switched on, using the key fob, lock the car and unlock it. Now, if you want to raise the car, press and hold the headlight and unlock button on the key and the car will rise! If you want to lower it, you have to press the headlight and lock button. Pretty neat!”
Anybody has tried this? Mine doesn’t work…
Post #1064702 4th Apr 2025 10:48pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
This isn't exactly new, it's been available on a few cars like the Disco 4 and possibly even Disco 3 Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1064704 4th Apr 2025 11:31pm
Retroanaconda
Detailed the manual, which nobody ever reads any more it seems.
Post #1064728 5th Apr 2025 9:19am
