  • You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > In Car Electronics > Double Cab rear 12v socket - help!
WightRover
United Kingdom 2011 Defender 110 Puma 2.2 DCPU Galway Green
A little shout for help from a newbie...
Im looking to put a 12v socket in the loadspace of my 61 plate 110 DC utility landy, Ive read heaps of posts but nothing quite the same as I see. Someone pointed me to a pair of wires behind the "speaker" panel left hand side... there are in fact 2 wires there, but no power in any condition, ignition on/off or engine running. Photo attached - they look like green/yellow and red/blue.
Can anyone help ID these, or point me in the direction of a wiring diagram. I have no blown fuses, but if these wires are for an aux not yet connected, then maybe there is no fuse fitted...?
Thanks in advance
Wight Rover
Post #1064497 2nd Apr 2025 11:51am
Martin
Site Admin
They are speaker wires, black/yellow and black/orange.
You are looking for a thick(ish) purple wire, typically on the right hand side of the tub (opposite side to the numberplate light)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1064512 2nd Apr 2025 2:17pm
Martin is correct as above, it’s worth noting if not known already that, once found that connection is permanent live also, so be sure nothing is connected permanently without a switch or unplugged.
It probably needs a fuse inline as well to lower its current rating a little perhaps 15A. WeWillWin🇬🇧🇺🇸
Post #1064517 2nd Apr 2025 3:14pm
