Home > Td5 > Idler puley - torque settings
alexatnd
Hi,
Noticed the idler pulley sitting at the top of the water pump housing of Gertie my TD5 was squeaking ratrher a lot on startup so as I'm replacing an injector thought I'd replace. it. Removed the anciliary drive belt and replaced pulley but nowhere can i find a torque seting for its bolt.
Been through the haynes manual cant even find. a picturwe of how the belt is supposed to be fitted ( pictures of. 200 and 30 Tdis , but not TD5 .. ).
Can someone point me at the correct torque setting for it?
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost
Effie - 2004 110 TD5 County
Post #1064495 2nd Apr 2025 10:25am
excossack
Page 1-14 Image 14.106 of the Haynes manual shows a non-aircon drive belt layout. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1064553 3rd Apr 2025 8:03am
TexasRover
You can just use generic torque settings, this is not a particularly challenged connection:
https://www.fixingsmegastore.co.uk/help/metric-bolt-torques
What is it M10? 50-55 Nm. aka just tight, not crazy tight or two 'click' an a medium impact driver.
Post #1064554 3rd Apr 2025 8:10am
alexatnd
And you're right ! was concentrating on previous page grumbling about not seeing the TD5 entry that i missed it.
Many thanks
Post #1064572 3rd Apr 2025 11:55am
alexatnd
actually did it to 45 nm in the end
but useful link thanks
Post #1064573 3rd Apr 2025 11:56am
