![]() | Home > Td5 > TD5 electrical gremlin (53 plate defender) |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
Welcome to the forum
![]() Out of interest, when you turn the key and get the symptoms you describe, do you hear the fuel pump whirring ? Reason I ask is that I have the ability to isolate the fuel pump from the ignition and when I forget and turn on the ignition with the fuel pump isolated, I get exactly what you describe.... No MIL/Preheat lights and temp gauge goes to the max. How that is linked into the Ignition/Fuel Pump relays god only knows ![]() ![]() |
tomw2000 Member Since: 12 Dec 2011 Location: Lincolnshire Posts: 4 ![]() ![]() |
hey
![]() hmm, ok not listened for the fuel pump specifically - but when I get the symptons I decribed (no orange engine or squiggly coil lights) the whole vehicle is very quiet...so doesn't sound like the fuel pump is running when the warning lights and the start fail.... Hmmm. (I'm not mechanically handy at all, so it's all gibberish to me). |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 ![]() ![]() |
Listen under the rear drivers side wheel arch. You should here it when you put the ignition on. Current:D4 HSE
Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
If the temp guage shoots up, it could be the cut out switch under the bonnet... if this is open circuit it gives the same symptoms.
Of course, you could have an annoying break in the loom somewhere causing this. ![]() |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
Hello TomW2000, and welcome to Defender 2.net.
I would expect you have an issue with the main relay, which is located next to the fuse box beneath the drivers seat. You should hear and feel it click as you switch the ignition to position II. Give it a wiggle, and see if it changes things? Give us a call on 01472 812900 if you'd like to talk to someone about it, and we'll be happy to assist you. |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
on my last td5 the blue loom clip was coming apart causing similar issues. if the speedo goes mad aswell as the fuel guge thats sympton of the blue clip thing. also oil in loom
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5799 ![]() ![]() |
Sounds like main fuses (under drivers seat) or ignition switch, but if Gary, at Alive is offering help, take it, he has helped me solve problems on mine.
![]() ![]() ![]() Andy |
Many thanks for all the ideas guys. I'll pass on to mechanic to see if they offer possible lines of investigation
Update: collected car earlier. Started and ran fine. Will feedback if same issue appears.
To clarify for now only 'ignition relay' has been replaced Thanks again all ![]() |
