Home > Puma (Tdci) > Rear door lock/central locking.
BrickBox
Afternoon all….!
I have replaced my rear door lock and swapped the barrel over. Easy job…
All went back to together smoothly. However, now my central locking doesn’t lock the door and the key also doesn’t. It did before I swapped in the new mechanism.
The central locking is working when and the key barrel is also. I feel like it’s more of an alignment issue, possibly? The door is latching and opening fine, that alignment is fine. There also doesn’t seem like there is much movement for alignment either.
Hopefully it’s just something daft that I’ve missed.
Cheers Smile 2008 2.4 110 Utility Station Wagon XS.
Post #1064308 31st Mar 2025 2:57pm
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
Does it work if you move the small black tab on the mechanism to the opposite sweep of the arc? Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1064320 31st Mar 2025 4:49pm
