Home > Technical > Towbar extender for bike rack
Page 11 of 11 <123 ... 91011
Leeroy
United Kingdom 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
OEM for the 130 I believe but worked on mine and also assisted with the caravan Alko hitch
Post #902565 11th May 2021 2:44pm
B4Lamb
Wales 2007 Defender 90 Puma 2.4 HT Galway Green
markb110 wrote:
DonH2000 wrote:
Excellent, looks great but when my bike rack was attached to a Dixon Bate detachable tow bar there was quite a lot of "slack" and movement in it which meant I went back to a rigid attachment system.
Have you managed to make to make it rigid?
Tip here. Weld two nuts to the top of the slider plate ( one each side), then run a bolt through to take up the slack and stop it from rocking.
:it:
No need to weld nuts on a Dixon Bate, it's thick enough to drill and tap 2 M8 holes either side then fit two M8 screws with a lock nut to stop it rocking on the adjusting pin. "You are never to old to learn something new"
Post #902708 12th May 2021 4:35pm
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
For those after a simple extension to bring out the towbar far enough to clear the rear spare I found this on Amazon. It’s obviously no use if you still want to tow when bike rack isn’t in use…£24
Post #908726 21st Jun 2021 7:57am
sjc501
I found this on the 4x4 overlander site Nakatanenga Cycle Carrier Adapter .Cost 185 but you can attach and remove when required . I need something to carry 2/3 Heavy downhill bikes currently I'm using a Dave cooper set up designed for a motorbike but can be removed quickly
Post #909443 25th Jun 2021 4:24pm
Rugratnav
Hi Leeroy,
I’m having the same issue as everyone else!
How far out from the rear X-member does this put the tow ball? Does it clear the spare wheel?
Thanks
John In Yorkshire, but near enough to the Lancashire border!
Post #939116 23rd Jan 2022 11:29pm
Vitesse
Extender removable
I fitted this extension today. Haven’t used it yet but it seems v strong It bolts on to the standard tow ball and extends by 250 mm
 2015 90 XS Santorini Black
Post #967033 7th Oct 2022 6:02pm
B4Lamb
That's a lot of cantilever on the tow ball but okay for a bike rack I suppose. "You are never to old to learn something new"
Post #967045 7th Oct 2022 8:34pm
LR90XS2011
I too would be worried about the load imposed on the 2 bolts with those simple bolts on extensions, fine for a bike rake put perhaps not so good with 100kg vertical towbar load from a caravan, (or more with some trailers). DEFENDER 90 TDCI XS,
Post #967050 8th Oct 2022 5:15am
Vitesse
Yep. Totally agree. The part is specifically designed for bike carrier and 80kg load. No more than that and certainly not for normal towing. 2015 90 XS Santorini Black
Post #967052 8th Oct 2022 8:25am
MussEd
It explicitly states not to be used for towing - purely for the bike rack Thumbs Up
Post #968549 21st Oct 2022 1:27pm
pmason1973
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
Re: Extender removable
Hi Vitesse. Has this help up ok? I'm thinking of doing the same thing but with a bigger rack (https://pbr.co.uk/products/wheel-support-bike-rack) and concerned about the leverage on the first tow ball. Many thanks, Paul.
Post #998881 6th Jul 2023 12:15pm
pmason1973
Vitesse, one more question. Is it the 200mm or the 250mm length extender? Thanks
Post #998900 6th Jul 2023 1:47pm
Toucanspeed
United Kingdom 2015 Defender 90 Puma 2.2 CSW Indus Silver
Oris Disco 2 towball
I have a spare D2 towball if anyone wants it. They are approx 220mm from flange to centre of the ball. £15 plus postage or collect from near Stonehenge.
Post #1064182 29th Mar 2025 9:32am
leonvh
Belgium 2013 Defender 110 Puma 2.2 SW Barolo Black
I use this extender from Nakatanenga. Only for a bike-rack, not for towing.
Post #1064216 29th Mar 2025 7:23pm
Toucanspeed
9” from flange to the centre of the ball
Post #1064240 30th Mar 2025 3:49pm
