Home > Camping, Caravanning and Holidays > Water storage
Betsy
 1999 Defender 110 Td5 HT Coniston Green
Water storage
Good evening
I’m looking at options for water storage ideas for my 110 camper, originally I was thinking water storage under the rear wheel arch to make use of the space, and then a pump to a tap inside. However after watching Boris the defender on YouTube, I’m thinking a 15/20l litre bottle inside, this will avoid the water freezing and is easier for maintaining, I would then opt for a whale hand pump tap to avoid unnecessary drainage of the 2nd battery, and this could be mounted straight onto the bottle.
Has anyone done similar, one concern is condensation building up on the outside of the bottle and dripping everywhere, as I currently keep a litre of water in the under seat storage and that condensates, this may be due to the diesel heater.
Is there any other pros and cons
Thanks
Post #1060590 14th Feb 2025 9:11pm
Betsy
Like this
Post #1060591 14th Feb 2025 9:13pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
That's a nice interior. We went for Hunersdorff canisters with tap. Usually we carry a 10 litre but I've made the box/holder so that a 22l also fits (2nd picture). For us a pump and sink is unnecessary.
We've never had condensation there, even when it was dripping from the ceiling Smile
Post #1060603 15th Feb 2025 6:38am
revd
20L with tap from Front Runner, haven’t decided where to site it yet but will be inside and as close to the floor as possible to keep the weight low down.
Post #1060606 15th Feb 2025 7:20am
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
I have the dometic 11 water jug and tap works pretty well and I keep a 20l life saver jerry can on the side 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1060634 15th Feb 2025 2:26pm
Betsy
That’s good new, I was concerned about it getting everything dam, thanks
Post #1060637 15th Feb 2025 3:32pm
jst
I have a front runner one on rear passenger arch external, filled internally with external tap through rear x member. You could draw from it internally with whale submerged hand pump. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1060648 15th Feb 2025 5:56pm
jst
https://www.frontrunneroutfitters.com/en/u...xwQAvD_BwE Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1060650 15th Feb 2025 5:57pm
macfrank
We only get condensation on bare metal surfaces and windows. I guess this is partly because they're getting a few degrees cooler that the interior and partly because of their smooth surfaces where water drops form easier than on rough surfaces. Those canisters are not as smooth as a glass or PET bottle.
Carpets and roof lining can also get humid but you'll only notice when you touch them. Also our curtains help to buffer some of the night's humidity (they're about the only cotton fabric we have (fire protected)).
Post #1060652 15th Feb 2025 6:17pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
I also installed the 22L canister.
I installed the BOXIO portable sink, too, i.e. another 5L for dish washing
https://boxio.fr/en/products/evier-portable
... After all, almost 30L for cooking, washing, ...
In Africa, I add 2...4x 5L canisters of pure drinking water (on the roof)
I've been thinking about the Frontrunner 40L in the rear wheelbase. As for now, cleaning my canisters is straight forward - but Frontrunner would be better if I needed more empty space inside
Post #1060667 15th Feb 2025 8:47pm
Lightwater
Australia
This is a Freelander:
In outback Australia we can only last as long as our water. That is the first thing to run out. Carry 2 x 10L, 8 x 5L plus quite a few small bottles. We have it as central & as low as possible. Sometimes we buy an additional couple of 10L disposable packs. We each can last on 2.5L per day.
We lined the car everywhere with acoustic foam. The added benefit is it stopped all the condensation, as we mostly sleep in the car which generates a lot of moisture simply from breathing.
Also cover all the windows with windscreen sunscreens cut to fit every window. That stopped pretty much most of the window condensation. Double thickness on windscreen.
Ceiling with 25mm minimum to 45mm acoustic foam & polyester batts, they are thin.
 Visitor - Freelander owner
Post #1064017 27th Mar 2025 10:56am
