![]() | Home > Puma (Tdci) > Fuel filter orientation |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 678 ![]() ![]() |
they can be a pain to twist and lock into position so you are confident that its right...
and because I know this im careful to take note of the orientation of the old filter when removing it and dropping it out of the head...and make sure the new one is offered up in the same orientation... you usually feel the little give when its lined up and ready to push in, but as said the twist to lock can be a pain, and diesel on can and hands doesn't help ![]() |
Waka56 Member Since: 08 Nov 2023 Location: Hamburg Posts: 170 ![]() ![]() |
I find it even worse removing it to be honest, to scared to pull sometimes as I'm never sure if that's the unlocked position
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20691 ![]() ![]() |
It’s a bayonet fitting, but iirc you are righ, a more clear indicator of it being locked in the correct place in a visible location would have been preferable. TheThunderRolls🇬🇧🇺🇸
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2461 ![]() ![]() ![]() |
By the way, I got this picture for those curious how this wonderful plastic crap looks inside
![]() Click image to enlarge Puma 110" SW ............................................................. Earth first. Other planets later |
