Home > In Car Electronics > Subwoofer in battery box under seat?
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
Hey friends. I was watching a Youtube video, in which a guy put a powered sub in the battery box, next to the battery under the seat. I love this idea and was wondering if anyone else has attempted this?
&t=19s
 1989 Defender 90
2022 Defender 110 SE
DIY’er | Always learning
Post #1063862 25th Mar 2025 5:32pm
Chicken Drumstick
tbh seems completely the wrong kind of vehicle to be worrying about subs.... I don't even have a working stereo in the 90! Rolling with laughter
Post #1063864 25th Mar 2025 5:49pm
Soulrider911
Laughing understandable. I am putting in dash speakers in mine and figured if I could stuff a sub in the battery box why not Very Happy 1989 Defender 90
Post #1063865 25th Mar 2025 5:56pm
bankz5152
Not best best place imo. Prone to water ingress and the reverb off the body would be awful.
Best spot is back of the cubby or under the resr seats if a 110
Post #1063867 25th Mar 2025 6:12pm
As above, not an ideal location, you might be able to mount in the lid though, but you’d need a passive set up.
The trouble is your need to custom make the plates, as in my opinion it’d be too thin, also your struggle to fit more than 8” or 10”
You’d also need to ensure basket / magnet clearance to the rear, shallow mount might work though depends on the depth available.
There isn’t much excursion room above either as the seats sit low, so you’d have to look at custom fabrication, there is the front seatbox face, but dia is limited, possibly too limited. WeWillWin🇬🇧🇺🇸
Post #1063885 25th Mar 2025 8:33pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
"tbh seems completely the wrong kind of vehicle to be worrying about subs...."
I just wonder what kind of music matches the personality of someone who would put high-end sound equipment in a truck.
I'm betting heavy metal or wannabe gangsta rap. Your guess? Your own music?
Peter
Post #1063929 26th Mar 2025 10:36am
Chicken Drumstick
I see you are in CA, I doubt damp or water are likely to be issues and I've not personally seen any water in the battery box before. Although they are prone to rotting out, so may have holes to the outside, which might be where some people see water ingress, esp if they then do deep water wading.
On my vehicles I've often used the space under the seat for some additional storage, such as a set of jump leads, power steering fluid and some other spares that have been handy from time to time.
There are limited locations to safely put any kind of sub in a Defender, so I can see this potentially working. Although I've also often added sound proofing material on the seatbox, so the bass might end up being a bit muffled being in a sealed box under the seat. But you'd really need to give it a try.
You'd also want to make sure you leave a big enough hole to get the battery in and out of. The battery sits offset, so it sort of comes out at an angle from the opening. I also normally run a larger battery, so you often need more room to lift it in and out.
Post #1063935 26th Mar 2025 10:59am
Linds Hanson
Best place3 is under cubby box with lots of sound deadening on seat box, but if you must hide it away then electric box under drivers seat with a speaker grille fitted to cover plate.
Post #1063938 26th Mar 2025 11:40am
