![]() | Home > Td5 > defender TD5 90 10p 2000 |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 905 ![]() ![]() ![]() |
Hi
I replaced an in tank fuel pump on a TD5 a few years ago. The best price back then was offered by Maltings who will provide a further discount if you join their mailing list. From what I remember the TD5 fuel tank is a different shape to the one fitted in the TD5 Discovery and therefore the level float assembly is different. I remember finding cheap fuel pumps but they were for Disco's. I would only fit a VDO, Lucas or (if you can find one) Bearmach fuel pump as the cheap Chinese ones don't appear to last that long. There is a great write up on the forum on fitting a circular marine waterproof hatch to change the tank fuel pump. I went down this route as it looks really professional as is what really should have been factory fitted for ease of access to to pump. https://www.ebay.co.uk/itm/275341558658?fi...R7aivdq5ZQ Jim |
Dover mike Member Since: 01 Aug 2023 Location: Dover kent Posts: 21 ![]() ![]() ![]() |
hi mate thanks when i fitted the galvanised chassis i done an ally cut out in the floor the one i found was for a defender Whats VDO ??
Hi
VDO is the pumps that your Landy would have been fitted with at the factory, but branded Land Rover. They are £250+ but sometimes you can find them on special offer. Lucas is a good pump and as you have a hatch cut already you can always easily change in the future. Below is the link I used for my hatch: https://www.defender2.net/forum/topic71836...pump+hatch Jim |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 545 ![]() ![]() |
Disco ones fit just swap the float arm assembly over, that's what's in mine.
