![]() | Home > Maintenance & Modifications > Brownchurch HD Roof Rack - Support legs - how to fix? |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1240 ![]() ![]() |
I was fortunate to purchase this rather nice Brownchurch Rack yesterday. It comes with ladder and the original 4 support legs being the HD model.
My question is how to fix the front legs? I have searched photos and cant see how it is done. Anyone got one and could explain or share a photo please? I am assuming you have to drill /tap the windscreen hinge or drill out the pin and replace with a nut and bolt? Thanks ![]() 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 208 ![]() ![]() ![]() |
You drill through the middle bolt hole of the windscreen hinge block from the inside, then fix the legs with a longer bolt and Nyloc nut (nut on the inside).
Some anti corrosion paste on the bolt would go down well! LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
