![]() | Home > Maintenance & Modifications > Actuator or door latch |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2216 ![]() ![]() |
I would check the wiring to the actuator, especially from the pillar to the door to see if it’s fractured as that could restrict the current getting to the actuator. A way to test the actuator is to disconnect the wiring from the actuator and use a separate negative and fused positive “ jump wire” from the battery to the actuator to see if it now works ok. If not it will be the actuator.
