Home > General & Technical (L663) > BF Goodrich tyres mixing KM2 & KM3 on the same axle
TaylorTD5
England 2002 Defender 90 Td5 PU Keswick Green
Hi I wonder if anyone has experience of mixing BF Goodrich MT tyres one is a KM2 and one a KM3 but mixing one on the same axle both tyres are the same size any thoughts would be appreciated
Thanks
Post #1063359 19th Mar 2025 11:22pm
Chicken Drumstick
It isn't illegal, but generally not recommended.
As this is in the New Defender section, the cost/value of these vehicles. I'd have thought running matching tyres would be only a minor cost for such a vehicle.
Post #1063362 20th Mar 2025 12:32am
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Its never good practice to mix tyre makes and models on the same axle as each tyre has its own individual properties and it may result in uneven grip and braking, which you don't want in an emergency situation. In heavy braking situations it can cause the vehicle you veer to one side due to different compounds used to construct the tyre and the tread pattern.
Not illegal though..
Jim
Post #1063366 20th Mar 2025 4:31am
Chicken Drumstick
With ABS and DSC it is hugely unlikely to cause the vehicle to veer to one side. And even on older vehicles I suspect this is overhyped to the extent it can occur. Else it would be illegal. Remember an MoT test for even braking force. If mixed tyres really were an issue, it would have been addressed decades ago.
Think of it more akin to wearing odd shoes. There is a small chance it may cause you to trip. But the biggest thing is it looks odd.
Post #1063378 20th Mar 2025 10:11am
LR Nuts
As stated ...... not recommended.
I only run with 4 identical wheels n tyres. The spare and a second spare are of the same as the vehicle .
When I buy tyres, I always buy 6 tyres to replace the 6 wheels I have.
Post #1063385 20th Mar 2025 10:53am
In an ideal world matching 4 road wheel tyres and a spare, all of the same type.
Or at least matching on the same axle.
You can bet if you don’t get a matching spare, you’ll need it and then that’s when younger problems with matching, plus availability is a problem. TheThunderRolls🇬🇧🇺🇸
Post #1063393 20th Mar 2025 11:25am
Moo
Ukraine
Never understood the skipping on tyres. I change mine at 4mm and always buy as a set. My family is too precious to me for penny pinching.
As others have said, not illegal but why would you on a £70k plus car? Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1063414 20th Mar 2025 3:22pm
TaylorTD5
Sorry I’ve placed this on the wrong forum
The car is a 25yr old Defender TD5 90 which is off road 50% of the time
Thanks
Post #1063498 21st Mar 2025 9:46am
