![]() | Home > Maintenance & Modifications > TD5 clutch issue? |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1184 ![]() ![]() ![]() |
Apologise for highjacked this thread, but actually following these discussions, and since I currently have my clutch assembly out of the car, I decided to modify my Td5 clutch to have both a bottom and top adjustment screw. This is quite simple by adding a bolt with captive nut at the top (rest height) location
With the overcenter spring and no top stop bolt the high position of the pedal is relying solely on the push rod adjustment holding it down at the correct height, which otherwise is too high. The push rod has some play where it meets the plunger and thus you loose some pedal travel taking up the slack before the plunger starts moving. I found that to raise the biting point you can end up with an uncomfortably high pedal. So a new top stop bolt to get the pedal at the correct height. Enough free play in the pushrod to ensure there is a free fluid path 'at rest' and a bottom adjustment bolt to avoid smashed up the floor padding and pushing the overcenter spring too far. I should be able to report back on this plan soon. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5919 ![]() ![]() ![]() |
I have been tempted to remove the SC but I didn't want to bring more pain to my door. I do have a borescope maybe i could insert this via the wading plug hole. The MC I purchased was a TRW one - same as the one that came off. The only LOF I have is the spring. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
While the drive to work after playing with the clutch went ok, the bite point being really low is annoying.
I popped into my local garage who do the MOT, welding. other jobs on the Landy I don't do and asked them to have a look for me. Next date 8th April!. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
![]() Click image to enlarge Well made the mods - high and low stops, will install over the weekend and let y'all know if it makes a difference. |
