Home > Puma (Tdci) > 2012 Puma front and rear diff oils
roche1800
Please can you advise on the oil type I need to the front and rear diffs and is it the same for the transmission/gear box.
Many thanks
Post #1062690 12th Mar 2025 12:06pm
https://www.castrol.com/en_gb/united-kingd...;id=469698
That is suitable for 2.2 or 2.4
Transfer box and diffs.
Gearbox must be GL4 which is different.* TheThunderRolls🇬🇧🇺🇸
Post #1062697 12th Mar 2025 2:06pm
TexasRover
While (open) axles and transfercase are pretty straight forward to lubricate, plain gearoil with some leeway in rating, a gearbox has syncros and the wrong oil can really mess with gear engagement. The syncros can also be of brass which is incompatible with some GL5 oils. So you really want to follow the manufacturers published gearbox fluid. I have not looked it up, but I sure that is well publicized.
Post #1062701 12th Mar 2025 2:21pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Transfer cases use brass shims in the centre diff so caution is warranted there as well. GL4 gear oils are fine for the transfer case. Some GL5 oils contain additives that can affect brass parts so do not use GL5 in a stock transfer case. If you fit an Ashcroft ATB centre diff in the transfer case, then it is ok to use GL5.
Post #1062714 12th Mar 2025 4:04pm
^^^^ This one is a bit difficult, though the Castrol guide suggests this to be the same for diffs and transfer box so I went for it.
Equally, the GL4 has different properties, where the Trnasfer box also has to prevent wear as well just the same as the axles.
One thing for sure though is GL4 in the gearbox, I went for that.
I’m my most recent full service, I followed the Castrol oil guide fully, very pleased with the results of that.
Only thing I’d suggest is performance dot4 brake fluid, not the cheaper one as the specs are a lot better, and higher boiling point.
I used to use Fuchs, but now am on Castrol.
Parts wise I use Genuine LR parts, fit and forget for a while. TheThunderRolls🇬🇧🇺🇸
Post #1062721 12th Mar 2025 6:23pm
roche1800
Is the Castrol fully or semi synthetic please
Post #1062725 12th Mar 2025 7:15pm
roche1800
This is much cheaper, what’s the difference please to someone who technically minded
https://www.opieoils.co.uk/p-724-castrol-t...dOEALw_wcB
Post #1062729 12th Mar 2025 7:59pm
The gold bottles which are fully synthetic, are often higher specs in the tech papers.
80/90 is thicker, particularly in the cold, and from that adds some drag and lower MPG.
There is lifespan as well, the cheaper stuff often has a shorter service interval.
My view is if it’s cheaper, it’s for a reason.
I buy quality, as it’s to protect the components, and those components aren’t cheap.
If you buy lower grade, it typically needs changing sooner, also bear in mind a diff is expensive as well as other items in the drivetrain.
As always, choice is choice.
Thumbs Up TheThunderRolls🇬🇧🇺🇸
Post #1062732 12th Mar 2025 8:21pm
Ianh
If you have not already read this topic on the subject of Puma gearbox, transfer box, diffs and engine Oils then it should help.
https://www.defender2.net/forum/topic8707.html
One thing to note while reading is that Castrol Syntrans Multivehicle 75W-90 is now sold under a different name - Castrol Transmax Manual Multivehicle 75W-90. https://www.broughtonlubricants.co.uk/cast...w-90-group
Post #1062734 12th Mar 2025 8:48pm
jbcollier
Redline MT-90 also has the correct spec for the transmission.
Post #1062735 12th Mar 2025 9:02pm
