![]() | Home > Technical > Instrument Cluster intermittent and lose of power |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5857 ![]() ![]() |
Really give the battery connections and main earth points a good check.
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 507 ![]() ![]() |
Sounds like bad contact on cluster connector
Esben Kold Member Since: 14 Oct 2023 Location: Horsens Posts: 32 ![]() ![]() ![]() |
I had the same symptoms when the big multi wire connector on the back of the cluster was loose.
Jimmyjamesj Member Since: 31 Jul 2021 Location: Sydney Posts: 4 ![]() ![]() ![]() |
Just to close the loop on this one...
Turnout out to be a fully instrument cluster, likely a capacitor dropping charge. replaced it with a second hand cluster and the Defender drives perfectly with no drop outs any more. Now to figure out why the headlights aren't working ![]() |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2243 ![]() ![]() |
The soldering on the 2.4 cluster is a known issue that can be fixed , several topics on here about it.
I expect your new used cluster now shows an incorrect mileage and vin number. |
Correct.
I did so much reading on posts here. Very helpful. I will get the clusters cloned so they match. |
