![]() | Home > Faults & Fixes (L663) > Leaking into the camera area behind Rear View Mirror |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3451 ![]() ![]() |
I’ve found so far that this 23MY 110 is far better built than my 21MY 90, though the 90 was one of the first batch off the line. 24MY 90 D250 HSE, Tasman Blue
County V8 Member Since: 07 Jun 2021 Location: UK Posts: 148 ![]() ![]() |
Get them to replace the windshield not bodge it up with black sealer.
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
So the car went in last Friday for the day……….. Friday afternoon I got a call from the service dept asking if they could keep the car over the weekend so that they could water test it on Monday. No call on Monday, Tuesday or Wednesday so I called them for a progress report……….. told the reception would call back……… they didn’t.
So today (Thursday ) I called into the showroom while I was in town. Asked to take a chair, would I like a tea or coffee? Things flashing through my mind - they’ve damaged the car and are trying to fix it? Nothing that serious - after following the LR procedure to fix this known issue they water tested the windscreen seal and found the car had more leaks letting water into the footwells on both sides through defective sealing behind the body colour trims on each A pillar. The trims were being refitted this afternoon and I’m collecting the car tomorrow afternoon. Hopefully at long mast they might also have cured the sound of a million bugs hitting the top of the windscreen at speeds over 65mph that they’ve been trying to suss out (unsuccessfully) and cure whenever the car has been in for other defect resolution. This is Land Rover product number 13 that I have owned since 1995 and it appears not to be a lucky number carwise for me - hopefully No 14 that should arrive sometime at the end of the year ( Meridian Audio parts permitting) Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Collected the car this afternoon - leaks all cured without replacing the windscreen (as per LR TSB instructions) and after a 70mph blast on the M9 no more sound of bugs hitting the top of the windscreen ! I hope now I have no reason to take the car in for unscheduled workshop work until my 90 arrives………. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Glad they got it sorted.
So far this 23MY XS I have seems pretty well screwed together, 90 was a bit creaky but it was one of the first off the line. 24MY 90 D250 HSE, Tasman Blue |
Mudlark Member Since: 14 Oct 2022 Location: North West Posts: 31 ![]() ![]() |
Just an update which I have just posted in a similar post https://www.defender2.net/forum/post1062155.html#1062155
Tim, did you get the impression from your dealership that a TSB had been issued? Thanks. |
