![]() | Home > Technical > Puma 2.2 dashboard warning lights and LED's |
Bradders130 Member Since: 27 Nov 2021 Location: Southampton Posts: 105 ![]() ![]() ![]() |
The hi/lo switch definitely alters the engine revs for sure and I know I have one as I have just changed the transfer case for a reconned one and the switch is in.
What needs to be considered here is whether there is a voltage across the two contacts A & K, as indicated in the photo, when low range is selected, which is not present when high range is selected. Assuming there is a voltage present, then I would have thought it was possible to solder in an appropriate sized LED. But, it wont be something I will be doing as it seems a bit superfluous. ![]() Click image to enlarge |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
The high/low can't be made functional just by fitting an LED, there's no software functionality in the cluster to drive it.
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 683 ![]() ![]() |
But can it be programmed to work, given that there is a socket on the board??
It’s a cluster/LR engineer level task, not dealer tech. It’s writing new software for the cluster to include the function to activate the lamp based on an input.
Cheers... that's what i was wondering..
So it's not a configurable option with the right tool in its normal set up..👍 |
