Home > Maintenance & Modifications > Door Sill Gap
foremanyvr
Canada 2002 Defender 110 Td5 DCPU Coniston Green
Door Sill Gap
This gap between door sill and body seems too large. Stones seem to get lodged in frequently.
Is there a piece missing or product I can get to seal this up?
Thanks!
Post #1062099 5th Mar 2025 7:20pm
ChrisDefender
There should be a foam strip to fill the gap. I used high density foam that will not absorb moisture or rot. Take off the sill, clean it all up, apply the foam and replace. Mine looks as good as the day it went on some three or four years ago.
I used foam that was wider than the gap so it compressed for a nice neat finish.
Post #1062101 5th Mar 2025 7:27pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
joint sealing tape used when fitting windows ("Kompriband"), self-adhesive, comes compressed to 2mm, expands to 15...25mm in a few hours
Post #1062121 5th Mar 2025 9:24pm
