![]() | Home > Faults & Fixes (L663) > Knocking from steering column |
Rovering80 Member Since: 26 May 2024 Location: Bishop's Stortford Posts: 5 ![]() ![]() |
Hello
I’m having this exact issue. Had it since new and I think it’s it’s always done it but I think it might be getting worse. Mentioned it to the dealer on a service but they said they couldn’t recreate it. Did you find a resolution? Matt Current: MY23 P400e HSE Dynamic |
Shoggers Member Since: 01 Feb 2024 Location: Holmfirth Posts: 3 ![]() ![]() |
Hi Matt,
Sorry for the late reply, I hadn't checked the forum for a while. The dealer did have trouble understanding the noise that I was explaining at first, but after I took them out for a drive it was quite obvious. They told me they replaced the lower UJ on the steering column. This resolved the issue an no more knocking noise... until this week. Exact same noise again. I'm going to get it booked in to see what they find this time. |
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 310 ![]() ![]() |
Might be worth checking the front lower control arms. I had a knock from the front going over pot holes and rippled roads which after some persuasion the dealer replaced the arms which cured the issue. It’s not unusual and there is a Topix note ref this .
