Driver Display missing Pixel?
Hello community
In my driver's display, this rectangle appears when turning on and off! Is this the case with all fully digital displays or is mine defective?
I would appreciate an answer.
Thank you, greetings Flo
Click image to enlargeDefender 110 XS, MY24, D250 Santurini Black
18th Feb 2025 10:39pm
Fifth Horseman
Looks like a possible software issue rather than a hardware fault.Defender 110 D300 X-Dynamic HSE MY22
18th Feb 2025 10:48pm
stevemfr
That would be one huge pixel!
It could still be hardware as well (bad connections to a segment of LCs in the D). If it on only appears on this screen, it will be software.
I would go back to LR as long as you're under warranty.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
19th Feb 2025 10:13am
Flo1610
It's true, a very large pixel
Just for better understanding, the "pixel" is not permanently black! I only see it for about 1 sec. when turning the cockpit on and off. In normal operation everything is so good. That's why I was interested in whether it was the same with others or only with my cockpit.Defender 110 XS, MY24, D250 Santurini Black
19th Feb 2025 10:24am
stevemfr
I will have to look for it. My D250 only has the partial cluster screen but I am in other Defenders often enough.
Wo in De bist Du denn? (Neugierig :-p)
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
