![]() | Home > Maintenance & Modifications > Seat Box side access ? |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1240 ![]() ![]() |
Hi
Has anyone fitted one of these? I am looking at something to access the box which on a pre tdci is an empty space. I cant think of any drawbacks unless I have missed something ![]() https://www.oryxsolutions.de/en/vehicle-eq...r-defender 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 344 ![]() ![]() ![]() |
Looks quite smart! Dunno if there's much difference with a 130, but I've seen slide out drawers custom made, but these require the little triangular body plate to swivel outward in order for the drawer to clear the body work. I'll see if I can dig up a photo. Defender 130 HCPU Td5 MY2000
Hope this works, see Schubladen Hinten here: http://www.thomas-kastens.de/menu3.html Defender 130 HCPU Td5 MY2000
Thanks 1984 One-Ten CSW
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17704 ![]() ![]() ![]() |
I've seen it done many times over the years, especially when replacement seats have been fitted which impede access. Bear in mind on later vehicles there is very little clearance between the panel and the door card though.
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
Make sure you seal up the box as well if you're putting anything water sensitive in there. Mine is always full of dust and splashes 😂
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1051 ![]() ![]() ![]() |
On my 2015 110, the plastic corner protectors over the carpet have marked the door card. They can't be more than 3mm thick! |
