Home > Tdi > 200tdi brake line query
billewizz
Hi guys I am currently building a 200tdi 90 rear drums front discs with the pressed steel type brake master cylinder can anyone advise which of the master cylinder ports go where as I didn’t strip it and can’t find this info any where thanks in advance.
Post #1060806 17th Feb 2025 10:20pm
GeorgeE
United Kingdom 1991 Defender 110 200 Tdi CSW Venetian Red
I think mine is cast, but if you are still stuck I can go and take a picture of mine and where the pipes go if that would be helpful?
Post #1061231 24th Feb 2025 3:34pm
Retroanaconda
The two ports at the front end go to the two front calipers individually. The rear port goes to a T-piece on the rear axle and from there to the rear calipers.
Post #1061235 24th Feb 2025 3:50pm
billewizz
Spot on thanks guys
Post #1063993 26th Mar 2025 10:53pm
