Home > Puma (Tdci) > Fuel Leak Off Pipe connector popping off
RACH-OB
Australia 2013 Defender 110 Puma 2.2 SW Alaska White
Hi there I have had an intermittent problem where the number 4 injector leak off pipe connector (green plastic thingy) is popping off the injector body. (2013 2.2)
When it happens I get an instant diesel smell in the cabin then when I pull over I have quite a lot of diesel spilling onto the ground. A lot of diesel.
It occurred today 5 times in a row causing me to have to pull over every couple of kms to reattach it only for it to do it again. When I re-connect it I give it a pull and confirm that it has seated properly.
Cant seem to find a topic on the forum about this. Has anyone else had this happen? Is this likely to be a fuel pressure issue caused by a blockage?
I am 300km from home so hoping to get an easy fix for now. Any ideas would be greatly appreciated.
Cheers.
Post #1060536 14th Feb 2025 10:57am
BrickBox
For £100 I’d buy a genuine leak off pipe to replace your current one and hopefully that will sort the problem.
The leak off pipe is a replacement item if you have had the injectors out in the past. Connector could be worn as it’s just plastic. 2008 2.4 110 Utility Station Wagon XS.
Post #1060537 14th Feb 2025 11:31am
andy63
I'd check the other pipes to confirm this is the case , but I'm pretty certain the leak off pipes are retained by a metal clip..
Is yours present?
Post #1060549 14th Feb 2025 2:37pm
Some are.retained by metal clips, most are retained by plastic clips which break easily. The clips are widely available e.g. from Ford, eBay, etc.
Post #1060554 14th Feb 2025 3:15pm
RACH-OB
Hi thanks for replies I have tried to attach a photo of the leak off connectors, hopefully it uploads. They are definitely plastic, no metal clip.
I also had purchased a genuine replacement leak off pipe several weeks ago but as the problem hadn't reappeared I did not install replace the current one.
Why would there be such a large amount of diesel coming out of the pipe?
Post #1060584 14th Feb 2025 8:23pm
RACH-OB
Cheers mate, interestingly the injectors were replaced by previous owner around 6 months ago.
Post #1060585 14th Feb 2025 8:28pm
RACH-OB
Is yours present?
Post #1060586 14th Feb 2025 8:28pm
andy63
So where exactly is your leak off pipe blowing off from..
The leak off fitting ...ie the black plastic bit with is retained in the injector by a metal clip..it's visible in the photos..
And possibly the best way to check this is to do a leak off test on all four injectors...I dont know the quantities at say tick over , but they should all be about the same..if not you have likely got a faulty injector..
Post #1060594 14th Feb 2025 10:46pm
RACH-OB
Thanks for the reply mate @andy63. Yeah the female green connector is disconnecting from the male piece attached to the injector.
Post #1060596 14th Feb 2025 11:33pm
