![]() | Home > Maintenance & Modifications > Re-routing Wiring Through Chassis To Rear |
TVR Tommy Member Since: 26 Nov 2013 Location: Bucks Posts: 183 ![]() ![]() ![]() |
I pulled the rear harness out to weld on a new crossmember. Putting it back was straight forward.
Someone on here mentioned using a ping pong ball on the end of the pull wire, so it doesn't get stuck in the chassis. Worked a treat. |
stark Member Since: 09 Mar 2021 Location: UK Posts: 30 ![]() |
What did you use as a pull cord? Did it not burn / melt during welding?
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17686 ![]() ![]() ![]() |
That was me:
So carefully pull the harness out of the chassis rail altogether (disconnect the front of the harness at the connector on the driver's side of the bulkhead (assuming RHD) and pull it out through the hole at the back of the chassis). Then do your welding. The do the ping pong ball and drain spring trick. It is surprisingly straightforward. Many people argue that it is better just to run the harness along the outside of the chassis rail anyway, citing that fact that it is visible and cannot abrade against anything in the chassis rail. My harness hadn't abraded on anything in 270,000 miles so I am not convinced about this argument, and feel it is less likely to become damaged inside the rail than outside. Last edited by blackwolf on 10th Feb 2025 11:12am. Edited 1 time in total |
No, because it isn't there when you weld. See post above. |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 810 ![]() ![]() ![]() |
When we did this job, we just used a bit of welding wire ![]() |
Thanks blackwolf, that's a great description on how to do it!
This method can work, if you pull the wire through with the harness as you pull the harness out, and leave the wire in place when you weld, however there is a risk of burning through the wire or welding it to the inside of the chassis. Do not try to pass a plain wire up the chassis leg as a means to pull the harness back though since there are various obstructions inside the chassis leg, such as spacer pieces, bolt tubes, and so on. If the wire passes the wrong side of one of these you may find that the wire has taken a route that the harness connector won't fit through. This is the reason for the ping pong ball as mentioned above - it guarantees that the drain spring follows a route along which the harness connector will fit. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2719 ![]() ![]() |
A length of 1.5mm twin and earth cable also works well, a small loop folded into the end and secured with tape serves the same important function as the ping pong ball 👍🏻
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20715 ![]() ![]() |
PVC coated green wire can be useful as well, it’s stiff enough to keep its rigidity, but doesn’t cause any damage, get more tricky if it’s long distance though.
I end up using 3M blue mask tape a lot as well, it has quite a lot of good uses, especially the 19mm or 20mm wide or whatever it is. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
