Home > Td5 > TD5 Windscreen Wipers
mpald
United Kingdom 2004 Defender 90 Td5 HT Keswick Green
Any advice appreciated.
I am working away and my wife has reported the windscreen wipers simply stopped and now will not work. She did not hear anything snapping or snagging, or a motor grinding to a halt [she tells me...].
She has checked the fuse and all seems to be fine.
Power is still going from the stalk to trigger the water jet - it is just the wiping is not happening.
Could this be that the wipers are simply seized?
Relay gone?
Earth?
Or the Motor?
Am having a bad run with the vehicle at the moment - new top end before Christmas, prop dropped off the other week - starting to look at Dacias enviously ...
Thank you for any suggestions.
Post #1059919 8th Feb 2025 11:24am
First step is to jiggle manually each wiper to see if one is seized, then report back.
Wiper failures are common on Defenders due to the value-engineered 1960s technology and generally straightforward to diagnose and fix.
Post #1059933 8th Feb 2025 12:52pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
As posted… start there. Another usual suspect is the park switch and or fuse. Check both as well.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1060068 9th Feb 2025 8:44pm
