- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
iainPS
Buying a P400e 110 … any advice? | |
I’m seriously considering buying a used p400e 110 defender. I’m just wondering if anyone has some good advice about things I should look for, year/production dates to avoid if there are production/batch issues, common faults I should keep an eye out for, spec items I might want to avoid or definitely get.
For context: I’ve been drooling over a 2023.5 110 x-dynamic HSE model with a good spec sheet. Seems to be a good model with lowish mileage. Are there things that have been included and then dropped (or the other way round) that is in earlier or later models that are worth worrying about?
Any suggestions/advice/views much appreciated
26th Jan 2025 6:07pm |
ardevd
No recommendations in particular other than being aware that the PHEv only makes sense if you can charge at home every day and primarily do relatively short journeys.
Other than the terribly designed boot floor, its a magnificent vehicle
8th Feb 2025 8:11am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
