![]() | Home > Puma (Tdci) > Rear Axle shock absorber Cups |
StressedComa Member Since: 23 Jul 2022 Location: Wakefield Posts: 69 ![]() ![]() |
I removed the cups off my axle when I fitted the pin to pin suspension on the rear. If you wanted to go back you could maybe use the Gwyn Lewis shock bush isolation washers with whichever bushes you have. Might be worth looking into it yourself first though.
They aren’t hard to get off, drill the spot welds and then I used a chisel just to finish knocking them off. |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 206 ![]() ![]() ![]() |
In my experience, Monroe shocks are not that great. We had a customer's car come in that just had Monroes fitted all round by another shop. The car was heaving and wallowing like a drunken sailer. They had saved his "old" shocks (100K+ and leaking a bit) and we refitted them. All back to normal.
I've no direct experience with Monroes meant for a Defender but they wouldn't be my first, second, or third choice. |
