Home > For Sale & Wanted > [For Sale] Garage clearout
So had another blitz of my garage clearout today.
I've got a couple of boxes of oil seals, bearings, parts etc. Ideally I'd like to sell them as a whole lot as opposed to trying to post little bitty parts everywhere.
the bulk is 300Tdi, although some Td5 and even a couple of 200Tdi bits from when I had one.
I don't know what it's all worth, so I'll stick a figure of £100 up and see where it goes from there... there's a lot of parts (might be a lot of pages of pictures)
I'll work through the part numbers in turn and label them up, although if you just google the numbers on the pics you'll see what's what.
So lots of hub oil seals, LT230 transfer box seals gaskets & bearings.
A new Warn 8274 brake overhaul kit
Tdi speedo cable
Wheel bearings
propshaft UJ
CDL relay (and the picture didn't come out, also several new relays that are used on the 10AS alarm unit to convert it to CDL)
Td5 MAF sensor, new
Td5 indicator repeater lights
Td5 bumper end cap rubber (used)
Td5 fuel guage
several boxes of bayonet bulbs. 5w, 21/5w, and some headlight bulbs
Quote a few headlight bulb "sockets" if you wanted to build your own light looms
2x "diesel fuel" badges to fit around the filler neck
Some Td5 switches; electric window,HRW, some older style HRW switches, couple of blanks.
Carling decals (and a carling switch)
Umpteen hub and axle gaskets
Tdi clock & RWW & cigarette lighter bezel panel...un bent
a random set of Suzuki vitara rear brake shoes, new
Brake aster cylinder overhaul kit.
Various random new suspension bolts & nuts ,
300Tdi timing belt lower pulley (new type) new
Various heated screen timer units
Voltage sensitive relay
Front air vent flap stick on foam
Heated mirror stick on pads new
Open to offers on the lot.
Located in Swindon, SN54DD
Cheers all Thumbs Up
Post #1059614 5th Feb 2025 7:33pm
And some more....
Various defender lights... Td5, early lenses, rear end door brake light, glass clear slidelight
1x 300Tdi glowplug (new)
new Td5/puma 110 rear/P38 drive flange kit
300Tdi rear crankshaft seal new
Post #1059615 5th Feb 2025 7:51pm
NickMc
Could you be arsed posting it to me.?
Post #1059642 6th Feb 2025 12:19am
I can stick it all in a box and get a price. pretty heavy though
Post #1059647 6th Feb 2025 6:14am
Still available.
All boxed up. Parcelfarce 48 is £17.95 delivery
Post #1064598 3rd Apr 2025 6:03pm
