Home > Faults & Fixes (L663) > Bass Buzz - Rear 3/4 Interior Panels - Defender 90
JAM911
HI Guys
Another question.
I am sorting interior rattles on my new to me D300 90...
It has a great music system but when turned up I get the occasional bass buzz / rattle from the low frequencies on the rear 3/4 interior panels.
Has anyone found a fix for this.
Surely the car should be able to handle the factory music system?
I am thinking I could add some anti rattle tape / felt at the edges of the panels or take the panels off and add some dynamat if I really have to.
Would rather not take the panels off if I don't have to.
Any fix ideas would be great.
Thank you
Post #1059415 3rd Feb 2025 7:33pm
eno
Australia
Not sure if this might be an issue but is the rear tray strapped down with the small side straps? Mine wasn't, not that I had noticed a rattle. But my 90 only has the Meridan system, not the surround.
On a different matter, if yours is a MY24 or MY25, has it got a tray cover and the cover over the jack, or does it have just one that you put on or below the tray?
Post #1059432 3rd Feb 2025 10:09pm
JAM911
I will have a look..
Post #1059505 4th Feb 2025 2:36pm
LandyMax
I think you'll have a job eliminating all the rattles and vibrations. My 90 HT has spent so much time at the dealership trying to get all the rattles and creaks resolved, I'm seriously considering going back to a Disco. They often fix them only for them to reappear after a couple of weeks, I've been told it's had all the panels in the back removed and anti rattle tape applied but there's still no improvement. It's a shame as other than all the creaking and rattling is perfect.
Post #1059595 5th Feb 2025 5:37pm
JAM911
Booked mine in to the dealer for rattles now.
It is under warranty so they can have a try first.
If they don't fix the problem I will pull the panels of myself add anti rattle tape and Dynamat.
Had a few quotes from specialist sound deadening companies but they want a min of £1500
for the work.
I am pretty sure I can do the same with a few Powerful UK youtube videos and £150 of Dynamat
To be honest they should come out of the Factory with no rattles and able to handle the installed sound system
Thank you
Post #1059733 6th Feb 2025 9:57pm
CincyRovers1
United States
I had an annoying bass rattle in the driver's door of my 110. Spent years trying to find the culprit and turns out it was the piece of felt behind the speaker grille that was fluttering around. I applied some Tesa tape to the honeycomb to secure the felt and the problem went away. I found it out after I installed Dynamat everywhere and applying silicone around the speaker grille tabs.
 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red)
𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone
𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone
Post #1060235 11th Feb 2025 3:27pm
JAM911
I will look into this.
Where did you apply the Dynamat please ?
Post #1060236 11th Feb 2025 4:18pm
CincyRovers1
United States
You can see some of the Dynamat on the inner door panel. I put it where I could without covering up any wires etc. I also put it along the backside of the door panel to help make the cabin a bit quieter. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
Post #1060237 11th Feb 2025 4:25pm
JAM911
Did you remove the rear 3/4 panels and add it there too ....
they are my main areas of squeak and rattles...
Post #1060238 11th Feb 2025 4:34pm
CincyRovers1
United States
No, I didn't. I have a 110, so all speakers are in the doors. Nor did I put any Dynamat behind the panels in the cargo area. Just in the doors and it made a noticeable difference. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
Post #1060390 12th Feb 2025 6:01pm
JAM911
Thanks for all the tips
Post #1060404 12th Feb 2025 7:48pm
JAM911
So this is an update.
I had my car booked into the dealer to sort out creaks and rattles but figured I could probably do a better job myself as I had more vested in the job.
I spent the last 2 days taking out the rear seats and then the rear 3/4 panels and b pillar trim.
Pretty hard work and slightly worrying as I expected to break a few bits.
I then put Dynamat, anti rattle tape and foam strips everywhere I could see that could be causing issues.
In the b pillars the tweeters were not at all secure and one of the rear speakers was loose.
I re assembled everything and now the sound system sounds loads better.
No rattles and buzzes that were present even at low volume.
All the rear creaks and noises that were present with the music off have now gone.
Well , nearly all gone, apart from one really annoying one that I still can't track down.
I think it could be from the tailgate, but sounds like it is from the rear 3/4 panel, but I need to get a mate to sit in the back to find out exactly where it is coming from.
Took a long time to sort out but worth it for my driving pleasure.
Thanks to Powerful UK for all the videos on Youtube they are a great help when doing any jobs.
Post #1061035 21st Feb 2025 5:07pm
