Home > Puma (Tdci) > ~30 second engine note change
pedrocandrade
Brazil 2011 Defender 110 Puma 2.4 SW Epsom Green
Here’s the enigma. Since about a year ago, I noticed that sometimes (once a month) the engine sound on my 2.4 Puma would change to a deeper growl for about 30 seconds before coming back to normal. It happened just after starting the engine, just as I was leaving home. More recently, the deep growl started to happen also in the middle of trips, with a warm engine. And again it also goes away after about 30 seconds. There’s no rattle, no noticeable loss or increase in power, just a change in engine sound. Like a different (deeper) exhaust note.
I searched the posts here in the forum but couldn’t find a similar symptom. I imagine a turbo actuator issue would change engine power. Same for MAP / MAF sensors. And as far as I know the 2.4 doesn’t have a DPF.
Does anyone have a clue as to what could be the culprit?
Many thanks!
Post #1059144 1st Feb 2025 1:54am
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi
No, you are correct that there is no DPF on the 2.4 just an EGR system.
Is there a dip in engine revs at standstill when you hear the "growl"?
Jim
Post #1059146 1st Feb 2025 4:23am
andy63
I have heard the type of noise you describe when working around the engine when running..
I have thought it was the viscous fan operating 🤔
Post #1059149 1st Feb 2025 8:23am
Johan_B
Sweden 2008 Defender 110 Puma 2.4 CSW Tonga Green
Do you have an AC?
It would be more frequent but maybe you don’t notice it most of the time.
Post #1059150 1st Feb 2025 8:37am
pedrocandrade
Hi, thanks for the replies. Here is a bit more detail:
- I do have an AC and it is working all the time. It does make a bit of a noise but it’s much softer.
- I only hear the noise when I rev the engine. Sometimes it’s “there” but unnoticeable because the engine is idling. But as soon as I raise the revs to say 1500 rpm the noise gets quite clear. And it goes away like magic after a few seconds. So there is no dip on the engine revs when the noise happens. No change at all in engine behavior.
- The viscous fan is an interesting idea. But why would it be engaging with the engine cold, right at startup?
Thanks again guys!
Post #1059165 1st Feb 2025 11:54am
MK
Viscous fan does engage shortly after starting the engine. Do not ask me why but I believe it was mentioned in this forum. Try a search. Puma 110" SW
Post #1059168 1st Feb 2025 12:12pm
andy63
When you park up and the fan has fluid present in the drive portion, that isn't cleared till the fan starts spinning and it will eventually be carried back to the resevoir, and of course won't be replaced until the bi metallic strip is warmed opening the valve to allow the fluid to flow into the coupling..
Having said all that I've heard that air type roar at times when I'm thinking it shouldn't be active....but I can't come up with another explanation for the noise...
Post #1059170 1st Feb 2025 12:41pm
pedrocandrade
That makes a lot of sense. It must be the fan. Thanks a lot for the replies and explanations!
It was the butler after all. 😄
Post #1059173 1st Feb 2025 2:13pm
Esben Kold
Denmark 2008 Defender 110 Puma 2.4 SW Galway Green
Edited [/code]
Post #1059192 1st Feb 2025 8:16pm
I have found this to be turbo actuation related, when completely cold.
Presumably, it’s more sticky at that point, albeit momentarily, which is enough to spin up more than it normally would do but momentarily.
If that tends to happen, lube those two pivots with light oil and I tend to find it’s a non issue.
The fan does have an affect, but it’s less noticeable.
Presumably it’s the former here, and not the latter.
Depends on whether you’d consider it slightly different, or fairly loud? WeWillWin🇬🇧🇺🇸
Post #1059215 1st Feb 2025 11:17pm
pedrocandrade
Oh it’s quite noticeable. The engine noise changes quite a bit. I’ll check the turbo actuator as well. Thanks a lot!
Post #1059225 2nd Feb 2025 12:44am
ickle
Can you temporarily remove the fan and see if the noise disappears ?
HTH Keith
Post #1059233 2nd Feb 2025 9:08am
andy63
Trouble is it's not a given your always hear the noise..or at least that's my case..but if you removed the fan and never heard it again I'd say that was conclusive..👍
If custom 90 has confirmed it's turbo related then you should be able to see the actuator move as the noise appears and leaves..or if you happened to have access to boost or maf data you should see it...but certainly in my case the noise always catches me unawares..and nearly always just when I'm working on it..given I'm stone deaf that's about my only chance of hearing it 😁
Post #1059239 2nd Feb 2025 10:05am
