Home > Td5 > Rear main seal, clutch and gearbox |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1121 |
Maybe it's me but that does not seem like a big oil leak to me. As long as it does not visible drip on your floor it's not really leaking in my opinion.
Clutch wise, yes you will see improvement with a new clutch at that mileage. I find they get stiffer with time as well. Yes when you get it there you could address any major oil leaks, but in my experience changing ok seals ' just in case' can actually result in leaks. On the movement when taking up drive, that is a little of a worry. It could be the clutch (hopefully) but could also an issue with the engine endfloat (axial play). You coul test for that by checking for axial play at the front pulley. When you take it all apart, change the pilot bearing and also check the clutch fork for cracking and replace if required. |
9th Apr 2023 5:14am |
MoosiMoosi Member Since: 06 Jan 2020 Location: Graz Posts: 22 |
Thanks. Should have said that the picture is not showing any oil. Definitely drips to the ground after a 20min drive.
Will check the pulley. Thanks. |
9th Apr 2023 6:03am |
Just checked the front pulley for any movement. Thank god there is none.
Could it be the dual mass fly wheel? looks like clutch and fly wheel needs a change. Thanks. |
9th Apr 2023 6:21pm |
Also to follow up on this just in case someone has a similiar issue.
Problem was a knackered dual mass fly wheel. New flywheel and clutch solved the issue.
New gearbox solved this as the input shaft of the gearbox had play and the input shaft seal was leaking as well. Lukas |
29th Jan 2025 11:31am |
Dover mike Member Since: 01 Aug 2023 Location: Dover kent Posts: 17 |
good morning mate i have just replaced my clutch / flywheel including seals and done my 90 td5 on my drive with no lifts just common sense it wasn't the easiest of jobs but i lifted the front end on wheel ramps that made the job easer i also took out the front seats and floor pans / gearbox tunnel for access i done mine in 2 days with the full Solid mass flywheel LOF kit including power spring what an amazing change it has made an another thing is to check all is tight under the engine when you remove the sump and as your there i replaced the gearbox and transfer box mounts
30th Jan 2025 11:39am |
