Home > Puma (Tdci) > 2.2 What Mileage should the timing chain be changed?
benh78
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
As per the title got a 2.2 on 118k wondering when I should be thinking about doing the timing chain or if it's not needed for a while
Post #1058842 28th Jan 2025 10:42pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi
I do believe that 2.2 and 2.4 timing chains are deemed good for the life of the engine/vehicle? Obviously if the timing chain snaps or jumps then the engine life ends there...
I would think that a timing chain is good for 150,000 miles and the life of the engine and the timing chain is dictated by the level of maintenance and frequency of oil changes of the engine as a whole? I'm sure someone will be along with a definitive answer in the next few hours.
Jim
Post #1058848 29th Jan 2025 4:14am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
If you pull the head, change the chain, tensioner, guides, and sprockets. Ford parts kits are cheap.
If you just bought the vehicle, look at the service records. If it has been cared for, it will be fine.
Post #1058850 29th Jan 2025 5:03am
BrickBox
jim4244 wrote:
Hi
Jim
It actually isnt the end of the engine. The pistons are pocketed enough for the valves to not touch the pistons, so you can put a new chain etc on and it’ll be fine. Obviously depending on how the chain let go, if it’s let go because you’ve gone from 6th to 2nd gear or something silly.
I forget what the terminology is for the engine design that the values can’t touch the pistons.
Edit:just googled. I believe the terminology is ‘non-interference engine’
“Non-interference engine - The pistons and valves will not come into contact, even if the timing belt or chain breaks” 2008 2.4 110 Utility Station Wagon XS.
Post #1058854 29th Jan 2025 8:59am
I tend to agree with Jbcollier and Brickbox here, there is chain guide wear there that you can get.
But, I really wouldn’t personally lean towards replacent for the sake of it, as if it isn’t broke don’t fix it.
You could come out with more issues than you started with, of course if you had access to it then you can get it done there and then if it was needed.
If it does snap, it doesn’t mean the engine is done for, but it is possible.
It isn’t something you want to happen if you can help it, but anything can happen.
Sensible regular oil changes with good quality engine oil I think is an important factor, there are people out there who hardly bother.
I think you can over and under service, I go by 12k or 2yrs whichever comes first, or relatively close to that where I can.
It can pay I think to replace air filter every year, plus garage servicing doesn’t include MAP and MAF cleaning, I think that should be done bi annually.
But regards the original subject, engine oil of quality and regular servicing is Important. TheThunder Rolls🇬🇧🇺🇸
Post #1058909 29th Jan 2025 6:11pm
benh78
Thanks for the ideas. Realistically most manufacturers in this case Ford will build the components of the engine to reach a minimum of 100k miles or 3 years. From internet searches the timing belt stretches and the auto adjuster can only compensate for so much stretch so I reckon around 150k miles with the regular oil changes I do. But I'll try and find a garage that has done a few to have listen and see if any of the current noises point to potentially doing it earlier.
Post #1059172 1st Feb 2025 12:16pm
Ianh
Worth checking out the transit forums as well for the 2.2, I believe the MK7 used a 2.2 . Transits tend to be pushed harder, driven less sympathetically , and serviced less frequently than our defenders. So you will probably get the worst case scenario. However there are a lot more 2.2 transits than Defenders, and they tend to rack up the miles, so more data on timing chain life should be available.
Post #1059184 1st Feb 2025 5:48pm
benh78 wrote:
... the timing belt stretches and the auto adjuster can only compensate for so much stretch ...
Don't confuse information about belts with information about chains which have a much longer life.
Post #1059185 1st Feb 2025 5:53pm
stichill99
timing chain
We took the opportunity to change the chain when our egr cooler split!
Post #1059260 2nd Feb 2025 10:47am
benh78
Thanks I know it’s a chain the chains do stretch
Post #1059289 2nd Feb 2025 2:40pm
jbcollier
Chains do not "stretch". They "lengthen" due to internal wear on the pins and rollers. Sorry to be a pendant but people hear "stretch" and think the metal of the chain is being pulled out of shape.
Post #1059291 2nd Feb 2025 2:46pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
VW engines were quite famous for their lengthening timing chaines - but I've never heard similar about the Transit engine
Post #1059301 2nd Feb 2025 5:12pm
Ianh
Am I missing something as I can’t see what the video has to do with a Puma 2.2 timing chain Confused
Even after the edit I still can’t see the videos relevance to the longevity of a 2.2 timing chain Neutral
Post #1059302 2nd Feb 2025 5:16pm
