Home > Puma (Tdci) > Grab handles
Landowner
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
Grab handles
Rather blindly I purchased two NTC5116 to fit to the rear cross member of my 2012 Puma. I just like the look, think it’s a quirky and part of a Land Rover.
Turns out one of the main bolts fixing the cross member is now right in the wrong place, stopping the handle sitting against the cross member. No grab handles for me then, unless anyone knows anything different!
Post #1058723 27th Jan 2025 4:11pm
Landowner wrote:
... one of the main bolts fixing the cross member ...
A photo would help, since (a) the cross-member isn't bolted on and (b) the grab handles should fit (at least they do on my 2007 cross-member, although I have ex-mil bumperettes). It would be interesting to see the bolts in question, perhaps seat-belt bracket mounts?
Post #1058724 27th Jan 2025 4:26pm
Landowner
Perhaps this version from LRParts just has a longer “ear”?
Post #1058728 27th Jan 2025 4:57pm
Retroanaconda
Or they’re not designed for vehicles with rear seats, as I assume yours does as those bolts are for the seatbelt mounts.
Post #1058733 27th Jan 2025 6:03pm
Landowner
Ah, that’s interesting. Just another reason to whip out the front facing seats in favour of inward facing then!
Post #1058734 27th Jan 2025 6:26pm
TexasRover
There is, off course, another good reasons to keep the front facing seats..
Post #1058736 27th Jan 2025 6:44pm
As noted, the screws are the reinforcing brackets for the rear seats (or seat belts), which I don't have. Perhaps makes a couple of spacers to clear the screw heads?
Post #1058737 27th Jan 2025 6:54pm
Chicken Drumstick
Re: Grab handles
It's only metal, you could drill some holes. Or if you plan to never pull on them, just stick em on! Thumbs Up
Seriously though, I'm not sure when the cross member changed, but they haven't been fitted for a long long time. Not even sure they have ever been on a 90/110.
They have an interesting story..... they shouldn't be on the back really, as they are completely useless there.
The original Land Rover, centre steer was built on a Jeep chassis and the Wilks had a WW2 Jeep they used on the farm as inspiration for the Land Rover.
If you look at an MB Jeep, you'll find these handles in the correct location (to be used by Squaddies to man handle the vehicle when stuck):
Complete with matching bolt holes & dimensions.
You can almost imagine the Rover boys having a big piles of Jeep bits left over and someone grabbing them and saying "hey, why don't we stick them on the back!" Mr. Green
Either that or it was a premonition that Land Rover owners would spend a great deal of time under the vehicle and would require a handle to pull themselves out from under the vehicle Rolling with laughter
Post #1058738 27th Jan 2025 7:00pm
Landowner
Wow! And there was I thinking that I shouldn’t post such a trivial post. The someone comes along and answers a long standing question.
Thank you, really interesting
Post #1058742 27th Jan 2025 7:52pm
The Jeep handles are different to even the earliest LR handles.
Every standard Defender rear cross-member has been drilled (or rather punched) to take grab handles or military bumperettes right up the the end of production in 2016. The only thing that gets in the way are the fasteners for the seat belt reinforcing brackets for the forward facing rearmost seats.
Post #1058744 27th Jan 2025 8:09pm
HardCharger
Somewhat related query to this, if I have already removed and disposed of the two rearmost forward facing seats that take up a lot of room in the cargo area, I no longer need the bracket thingie that is bolted between the rear wheel arch and the rear cross member? Mine were still there when I was fitting the Gwyn Lewis mud shields to the cross member. Can I safely remove these, no problem? Question No Better Friend, No Worse Enemy
Post #1058769 28th Jan 2025 4:07am
Retroanaconda
Yes, worth doing as they’re just an extra mud trap and there are enough of those underneath already.
Post #1058777 28th Jan 2025 9:04am
HardCharger wrote:
... Can I safely remove these, no problem? Question
Yes, as Retroanaconda says, you can, their only purpose is to anchor the seat belt mounting to the rear crossmember due to the weakness of the alloy rear buck. If you have no seats and no seatbelts in the back they are purposeless.
Post #1058779 28th Jan 2025 9:54am
HardCharger
What if say, some time in the future I decide to install the Gwyn Lewis Dickie Seat Base kits onto the rear arch, will keeping these brackets on make sense then or they are not required for these? Question
Would just like to know as I'm still on the fence on whether to install the additional seating on the rear or just keep it strictly cargo. I've had a few instances where I had to haul people and the in the cargo bay, they had to just sit on the rear wheel arches for the trip. No Better Friend, No Worse Enemy
Post #1058947 30th Jan 2025 7:23am
revd
I ordered a new 90HT from the factory in May 2002, when delivered the grab handles that had been confirmed on the build sheet as standard equipment were missing - supplying dealer Evans Halshaw shrugged and said that the spec had changed from 2002 to 2003 build and if I wanted them fitting I would have to pay.
Having just spent £17200 on my brand new Td5 I passed on their kind offer.
Post #1058951 30th Jan 2025 8:07am
