Home > General & Technical (L663) > Engine oil 0-20 or 0-30
billy2shots
I want to change the engine oil and filter on my 2000 mile D350.
When researching here and other sources, the information changes.
0-20 and 0-30 are recommended depending on the poster.
Is there a definitive correct choice.
To confuse things, Castrol Edge Pro (with titanium) 0-30 displays the correct JLR..... Code but the websites that recognise your car make and model also say that's the incorrect oil for your car and you should buy 0-20.
Confused.com
Post #1058696 27th Jan 2025 8:42am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi
0W20 seems a little thin to me and would only notionally cover your vehicle up to an ambient air temperature of 20C. That said I have only ever owned a D250 briefly and never had to service it.
In recent years manufacturers appear to be recommending thinner oils so that operational temperatures are reached quicker and there is less drag on engine internals to reduce emissions.
Jim
Post #1058697 27th Jan 2025 9:08am
mse
Specification is the most important element rather than viscosity
SAE 0W-30 meeting Jaguar Land Rover specification STJLR.03.5007
0w-20 is petrol. I suggest, for a voluntary change to tick to spec, you can buy it from the dealer if you can’t get it locally Mike
Post #1058702 27th Jan 2025 10:45am
DrRob
How do you tell the car it's had new oil for these interim oil changes? Still not figured that out.
GAP IID doesn't let you like it did on my old L322 Whistle MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie"
Many Range Rovers and Land Rovers over the years 😂
1949 80" - still in family since 1975
Post #1058703 27th Jan 2025 11:23am
mse
reset the service setting like in all cars
But if only an interim change you wouldnt tell it Mike
Post #1058704 27th Jan 2025 11:26am
DrRob
That's what I was thinking but how does the engine know it's had new oil for the "dilution" calculations? MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1058705 27th Jan 2025 11:27am
Retroanaconda
I’ve always used 0-30 as specified in the manual.
IIDtool can reset the service indicator. I always reset it even on interim changes.
Post #1058706 27th Jan 2025 11:29am
billy2shots
Thanks everyone.
I ignored some websites saying 0w 30 was incorrect for my vehicle.
Ordered 8l of Castrol Edge Pro with titanium STJLR.03.5007
Opie oils have a 15% discount off at the moment works out at £12.70 per litre
Post #1058725 27th Jan 2025 4:35pm
DrRob
Does that work even though oil service required not showing on dashboard? So, change oil then go into instrument menu and just press reset? MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1058743 27th Jan 2025 8:07pm
Retroanaconda
Yes. It just resets the counter to 21,000 miles.
Post #1058746 27th Jan 2025 8:12pm
DrRob
Great! Good to know it can reset the brain for oil dilution calculations Thumbs Up MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1058747 27th Jan 2025 8:14pm
rusty_wingnut
I am about to brave an oil change on my D300 - I'm not convinced it was done at last service as the oil is very black - and frankly it's just piece of mind for me!
Opie list oils to the spec above, does anyone know how much oil the D300 takes?
Post #1062510 10th Mar 2025 11:30am
miker
On most diesel engines the oil will look black the moment you've run the car!
Post #1062511 10th Mar 2025 11:44am
lightning
As above.
l had the oil changed and the oil was black immediately. The only way to make it look like oil for a short time, is to change it twice.
Post #1062540 10th Mar 2025 6:08pm
Retroanaconda
3l diesel takes 9.8 litres with a filter change.
Post #1062547 10th Mar 2025 7:09pm
