Home > Puma (Tdci) > Air conditioning rad/condenser?
Shep
2010 Defender 110 Puma 2.4 USW Orkney Grey
Got quite a bit of corrosion around the Air Con 'condenser' mounting brackets, I bought a new stainless steel frame and 4 brackets.
The original brackets are each fitted to the core with 4 pop rivets, I'm wondering what they are actually attached to and if I'm in danger of damaging or destroying the core by interfering with them?
Sorry if this sounds a bit lame but the cost of a new core is significant in my world Smile A man with no boat is a prisoner
Post #1058536 25th Jan 2025 12:27pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
You will have to be careful drilling out the rivets. It would be easy to also drill through the condenser which would blow your budget.
Post #1058617 26th Jan 2025 12:58am
neon1991
United Kingdom 2014 Defender 110 Puma 2.4 USW Firenze Red
Re: Air conditioning rad/condenser?
I hate to say it but the cost of the stainless frame would have probably been the same as the aftermarket condenser/rad. They attach without the need for a frame.
Post #1058651 26th Jan 2025 3:03pm
Dinnu
I have done it to mine, although I galvanized the original brackets, as stainless can promote galvanic corrosion.
It can be intimidating to drill the rivets, but as long as you keep your drill as perpendicular as possible, and set drill bit all the way in chuck so its short and you cannot reach the intercooler, you will be good. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1058664 26th Jan 2025 5:25pm
Shep
Thanks! I was wondering what the rivets are fixing too? Is there a plate on the core itself that the rivets hold on to? A man with no boat is a prisoner
Post #1058668 26th Jan 2025 6:27pm
Shep
Do you have a long to an aftermarket unit please? A man with no boat is a prisoner
Post #1058669 26th Jan 2025 6:29pm
Dinnu
Yes, there is a plate that is welded to the core. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1058679 26th Jan 2025 7:33pm
Shep
Thanks! A man with no boat is a prisoner
Post #1058685 26th Jan 2025 8:19pm
neon1991
Here you go
https://www.ebay.co.uk/itm/255748992788?mk...media=COPY
Post #1058686 26th Jan 2025 8:50pm
Shep
Thank you! A man with no boat is a prisoner
Post #1058689 26th Jan 2025 11:02pm
Vitesse
Just to report that I attempted the bracket change using the YRM stainless ones. Lovely product but sadly managed to nick the condenser with the drill bit and lost all the gas. Had to order a whole new assembly. £700 Heed all warnings with the drill bit!! 2015 90 XS Santorini Black
Post #1064353 31st Mar 2025 9:36pm
jbcollier
Your local aluminum welder could sort that.
Post #1064357 31st Mar 2025 9:43pm
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi
If you go for one of the aftermarket condensers you are better off replacing the fan with a larger one rather than trying to fit the original LR fan. The larger condenser and fan will also make your A/C way more effective. Also, give the 4 fan brackets a quick coat of black paint as it tidies everything up nicely and you wont see the brackets once the grill is back on.
Jim
Post #1064367 1st Apr 2025 5:31am
BrickBox
I’m not sure on the quality of these?
https://www.ebay.co.uk/itm/256867782906?mk...media=COPY 2008 2.4 110 Utility Station Wagon XS.
Post #1064377 1st Apr 2025 7:45am
jim4244
Maltings tend to sell fairly decent after market parts and I see that it is branded as "Eurospares"
The other Ebay link says that the condenser is unbranded.
Jim
Post #1064382 1st Apr 2025 8:50am
