Home > Technical > Defender 90 v8 starting issue
samuel_brulhart
Hong Kong
Hi landies, i’ve recently rebuilt my auto gearbox of my 3.9 v8 90 but i’ve got starting issues after that.
It just cranks but cant fire up the engine, the fuel pump runs when i turned the key, i tried to check the voltage of the ignition coil connection and there is no voltage there, then i jumped a lead directly from the battery to the ignition coil and it fires up straight away when i turned the key, that’s why i though its a ignition switch issue and relaced with a new one but no joy,
anyone has an idea about it? Many thanks!
Post #1058641 26th Jan 2025 10:50am
Romadog
Check Relays work correctly Thumbs Up
Post #1058657 26th Jan 2025 3:18pm
samuel_brulhart
Hong Kong
Thanks for the reply.
Yeah agree the relay might be the issue, will check the relays and also try a cable from the ignition switch to the ignition coil and see if it works.
Will post an update after that
Post #1058694 27th Jan 2025 4:03am
grafty99
Are the earth points on the transfer box and near the top of the bell housing good? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #1058698 27th Jan 2025 8:22am
