Home > BMW Engine Conversions > M57N with 8hp70
Page 2 of 2 <12
Les Brock
90dv wrote:
Any more details how you have fitted the Webasto heater? Just about to embark on fitting an M57 myself and want to put the webasto I have in as well.
Thanks
As James said, its flow through so you can just plumbed straight through which is how I used to run it on the 200Tdi
I fitted a non return valve this time, so when the engine is running it bypassees Webasto stright to heater, ( Little valve block by heater) when webasto running it goes through heater 1st then returning via block for warming inside 1st as fan motor runs on slow for de-frosting- may or may not keep it that way will see how it goes.
Control wise its via a T90 remote (so I can switch it on from tje house Very Happy )with timer in cab as well if needed, not used it yet
Fuel pick up is straight from tank
If you want any pics let me know
Post #1057589 16th Jan 2025 9:11pm
jst
Personally I would leave put the valve. Then engine running and eebasto running means hot heater quicker. Mine are plumbed to heater then a heat exchanger for a shower then back to block.
I run mine 10mins prior to an engine start Oct through to Mar. And sometimes first ten mins of a journey. Don't suffer 2.4 whist smoke start up then. One of my m57s has a thermo top C too mounted same configuration. Tbh m57 warms quickly so webasto is good for a pre warm on cold start but not needed when engine running. Heater and engine warm much quicker than my 2.4s.
Les, your attention to detail will mean it will be a top job and super over engineered, especially electrically. So yep I'll buy it. Do you have a line in the sand for it being a runner.
Have you upgraded brakes? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057605 16th Jan 2025 10:28pm
Les Brock
I'm waiting on props from Gwyn as for some reason using my 200Tdi chassis position for GB mounts I'm 30mm back from where it should be ....... Shocked
So nothing and I mean nothing fits without being a tad stretched at the front with Puma Prop or to long at back with 200 one
Engine wise it cant go any further forward and turbo actuator would hit the power steering box so dunno Question
Running it on stands the 8HP shifts as it should
I have standard TD5 Rad in at mo as Alisport one took 9 months to get Rolling Eyes so its still in the box Whistle as its too buddy cold to replace it all
wanting to fit Davies EWP150 as aux pump, I have just in case with the 8hp and 1.1 it revs a bit low on motorway but cant decide top hose like you have or bottom hose (any pics of yours ?)
other than that front eyebrows to go on, along with bonnet and a bit of general tidying up
Brake wise I changed calipers to 48mm 110 with stainless piston front and rear and upgraded to twin servo - hoping this will be ok
so still a little bit to do and then teething problems no doubt
Post #1058418 24th Jan 2025 10:00am
jst
sounds likes it coming along well then.
Have you bench tested the stat you have fitted, its worth knowing what temp it opens at and how much it opens. should be 88 and 12mm ish.
EWP i can take pics yes. mine is top hose with the power to it coming from thermo switch in the top hose so if thermostat is closed it wont run and then it only runs off the controller when temp hits certain figure.
Brake wise, cant comment on a 130 that is heavy so upgraded calipers and discs. a year prior to to engine swap. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1058492 24th Jan 2025 7:28pm
jst
Les Brock wrote:
your adaptor is far deeper than mine hence prop issue i suspect.
Have you swapped the PAS box pipe around to give more turbo clearance? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1058493 24th Jan 2025 7:30pm
Les Brock
Hi James.
House of Torque have reduced the length of their adaptor by 30mm which should bring everything back in line.(bit late for me but Gwyn came up trumps as usual
Could you get some pics of your EWP install when you have time please ?
As the weather is getting warmer (Wimp I know .... Laughing ) so will be looking to get that added in, as Allisport Rad is here to go in as well.
Will take the opportunity to check the stat opening temp Thumbs Up Regards
Les
Def 90 M57
Post #1062055 5th Mar 2025 11:33am
jst
Check stat first, and how many revs is 50 and 60mph? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1062070 5th Mar 2025 3:08pm
Les Brock
Will do
Ashcroft Ratio calculator 1.1 gives me Third to Eighth
50@ 1362
60@ 1635
70@ 1907
 Regards
Les
Def 90 M57
Post #1062075 5th Mar 2025 4:00pm
Les Brock
1.2 for comparison
 Regards
Les
Def 90 M57
Post #1062079 5th Mar 2025 4:43pm
jst
Mines a 1.3
You need good circulation, 2100 plus for adequate cooling.
Could always get a custom made wpump pulley? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1062128 5th Mar 2025 11:04pm
Page 2 of 2 <12
