Home > Puma (Tdci) > Prop shaft Phasing
keef9t
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Prop shaft Phasing
2007 2.4 Puma 90
Has anyone seen alignment marks on their prop shaft. If so, where are they and what do they look like.
I've taken the rear one off because it's out of phase, yokes should be in line (see photo).
Bearing in mind these things are balanced, I don't want to simply line the yokes up, only to find I've got it 180 degree out.
I can't see anything to guide me to the correct assembly. There are some marks, as shown. What looks like an arrow on the yoke could also be a capital A
 Life is short, so have your pudding first
2007 90 2.4Tdci County HT Stornaway
Discovery 1 200Tdi Sold
90 Turbo Diesel HT Sold
110 2.5NA CSW Stolen
88 Series II Sold
Meccano Set. Don't know what happened to that
Post #1058348 23rd Jan 2025 7:33pm
I just cleaned mine up, and used a little Tippex, a little white paint would do though
I marked the diff flange and prop flange, abd the transfer box end, then the prop flange to the yolks.
Basically just so everything goes back exactly where it was before.
Presumably you are changing UJ’s or are you replacing the prop? TheThunderRolls🇬🇧🇺🇸
Post #1058350 23rd Jan 2025 8:01pm
keef9t
Nothing wrong with the prop shaft other than being out of phase, so it will be put back after greasing and re-phasing. The problem is the apparent lack of alignment marks.
Post #1058352 23rd Jan 2025 8:34pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
What’s makes you sure out of phase is wrong?
Have you got a vibration?
Post #1058354 23rd Jan 2025 8:37pm
Dinnu
On a tdci, the rear prop shaft is also out of phase due to the nose up engine installation. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1058355 23rd Jan 2025 8:49pm
keef9t
On a Puma 90, my understanding is the yoke face on the transfer box is considered parallel to the yoke face on the rear axle, therefore they should be "in phase".
The front axle yoke face is considered to be at an angle to that on the transfer box so the yokes should be "out of phase".
Post #1058359 23rd Jan 2025 8:53pm
andy63
The props on my 110 were are as yours in the picture.. both front and back..
And the gwyn Lewis wide angle that are on now are fitted the way they were delivered ..ie phased
Worth noting that the splined joint on the original that I stripped have coarse deep groves with ball bearings...bit like a cv type joint.. so there is not a lot of scope for getting the phasing wrong.. one groove i think sets whats required , as each step is considerably..I forget how many channels around the shaft , but I have pictures somewhere if it helps..
Should also add my wsm calls for a phased prop but again I can't remember if it states the angle..
The originals and replacements have no issues with vibrations.
Post #1058360 23rd Jan 2025 8:59pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
I know. Out of phase. It's goofy but that is the way they are supposed to be. So don't fix them!
The real arguments start when you discuss phasing with a replacement shaft that has double-cardan joint added.
Post #1058362 23rd Jan 2025 9:00pm
andy63
Just seen your post..
Forget my rambling..it's for my 110..👍🤣
Post #1058363 23rd Jan 2025 9:01pm
keef9t
Having said what I did, a quick check on the workshop manual I have, Page 119 fig RR4199 says front and rear should be phased. So perhaps I'm wrong
Still can't see any alignment marks though.
Post #1058365 23rd Jan 2025 9:05pm
I'm fairly sure that there are no alignment marks on a standard Puma propshaft, Land-Rover no longer believes that there is any reason to dismantle the splined joint.
Post #1058371 23rd Jan 2025 9:42pm
^^^^ I believe this to be true, if there are any stamps or markings on them, it was probably just due to manufacturing process. TheThunderRolls🇬🇧🇺🇸
Post #1058394 23rd Jan 2025 11:39pm
Dinnu
Only true up to Td5. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1058401 24th Jan 2025 6:16am
keef9t
Thanks Dinnu, I think that's maybe where my confusion lay.
Front and rear prop shafts cleaned and greased. Re-fitted to vehicle, as found.
Post #1058438 24th Jan 2025 12:14pm
