Home > Puma (Tdci) > 2.2 Blow by and oil spray?
BobGFish
Switzerland 2014 Defender 110 Puma 2.2 SW Indus Silver
So I am shopping around for a 2014ish defender to buy. One with 70K when popping the oil filler cap sprayed quite a lot of oil. (bonnet and left hand wing) The 2nd with 120k hardly sprayed any oil but did have air flowing out like the first. Is this normal for all? Do they all spray oil or hardly any like the 2nd? I have watched a few videos of tail tale chuffing with the injector seals and neither did this. Thanks
Post #1058336 23rd Jan 2025 5:19pm
MK
The proper way is to check the hose out of the pcv that goes into the air intake. Puma 110" SW
Post #1058347 23rd Jan 2025 6:22pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
It can be a sign of engine wear but it is most often leaking injector seals. Some air release is normal. Lots? Nope.
Post #1058364 23rd Jan 2025 9:03pm
MK
I have seen both 2.4 and 2.2 TDCi engines, new and used, blowing a lot of air and oil droplets through the filler hole. Under load, rings expand and better seal the combustion chamber.
The best way to asses the health of the engine is via compression/leak down tests. Puma 110" SW
Post #1058368 23rd Jan 2025 9:18pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Idle & accélération okay ? Any fault codes ?
Post #1058369 23rd Jan 2025 9:27pm
BobGFish
Both seem to run OK. Was surprised at how much oil came out of lower milage one. Also surprised about how much air you could feel with hand although it a lot of air from fan. Both had no fault codes. Only drove one and it was fine. Will have a look at another and compare.
Post #1058662 26th Jan 2025 5:24pm
andy63
Was getting rid of a bit of Sahara sand from the top of my engine today 🫣🤣and while cleaning up and generally checking i removed the oil filler cap..
There was a healthy splash of oil. i see that as a good healthy supply of oil splashing around..it just gets carried by the air..
The cap itself just sits and pulses up and down if its free and sitting on the fill ..if you cover the hole with your hand it's a pretty neutral effect you feel.. positive and negative pulses... which sort of ties in with a trace I took with a tube down the dipstick hole which would ve direct crankcase..
All this just at tickover..ie 800rpm..
If i remember I'll get a trace of the oil filler and engine breather for comparison..👍
I'm not sure when I'll get rid of the red dust in the engine compartment🤔🫣🤣
Post #1058923 29th Jan 2025 9:22pm
TexasRover
While a petrol engine uses the engine 'vacuum' to create a negative crankcase pressure, on a diesel you don't have that negative pressure available so there is always a positive pressure which is bled off into the air intake (pre-turbo). In addition the combustion chamber pressure / airfill is much higher resulting in more blow-by past the piston rings
Obviously as the engine ages the blow-by will increase so it is relevant observation, but not really comparable with the old Cortina.
Post #1058935 29th Jan 2025 10:28pm
MK
That is nice!
Would you check it at different rpms? and under load? Whistle
 Puma 110" SW
Post #1058965 30th Jan 2025 12:14pm
andy63
I'll give the load testing a miss..that takes a little more setting up..😁
But here are traces of the gauge pressure through the oil filler cap , engine breather hose, and the dipstick tube..I've given the engine a quick blip of the accelerator in all the examples..
And the pressures are in milli bar down the left..
The time base is 100ms/division..ie 1 sec across the screen..👍
I left the breather hose connected while doing the oil filler and dip tube traces
Enjoy🤣
Oil filler..
Engine breather hose,
And oil dip tube,
Post #1058982 30th Jan 2025 1:30pm
