Home > BMW Engine Conversions > M57N with 8hp70 |
90dv Member Since: 29 Jun 2011 Location: Cumbria Posts: 39 |
Any more details how you have fitted the Webasto heater? Just about to embark on fitting an M57 myself and want to put the webasto I have in as well.
Thanks |
13th Jan 2025 9:20pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8162 |
What servo is that Les?
M57 won't need a webasto for getting to temp quickly for the heater. But they are useful for prewarming engine mines fitted same as yours les.so much more room in an m57 bay. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
14th Jan 2025 6:36pm |
Under drive or diff lock lever to side? Cheers
14th Jan 2025 6:37pm |
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 174 |
James, Servo I bought as a TD5 early Non ABS Ex Stock off Ebay with the expectation of fitting LoF Booster to it, arrived in Genuine LR Box with NSN Number on it, opened to find it already had adaptor on it already and it fitted staight to pedal box I'm assuming some MOD special for 300Tdi that required extra bracking effort of double servo or indeed very early TD5 poss when ABS was option ? - I did take some pics of part numbers/box if I can find them. |
14th Jan 2025 8:29pm |
No problem what can I help with, how I plumbed it in or electrics/fuel pick up ? |
14th Jan 2025 8:30pm |
Its for the underdrive, currently it's still sat in the box, seeing if its worth fitting or if I'll ever use it again lol |
14th Jan 2025 8:32pm |
Nope! Sold mine with last truck. Auto won't need it anyway. Cheers
14th Jan 2025 11:41pm |
Many would be good if you do find them. Looks like abs one. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
14th Jan 2025 11:42pm |
James
3 port cylinder on this the ABS one is only 2 port if memory serves me correctly |
15th Jan 2025 8:05am |
tommobot Member Since: 15 May 2018 Location: Stratford Upon Avon Posts: 29 |
Do you by any chance recall what top hose you've used heading into the radiator? Can't find something that nicely clearlys the power steering unit - Would almost like a smooth S profile.. I've got a very similar pipe, but it is twsited and doesn't sit quite as comfortably (I'd used a spare hose I had knocking about) |
15th Jan 2025 10:31am |
Both really, how have you plumbed it? Is it inline with the heater? I wasn’t sure if the Webasto was free flowing when not on. Do you have a separate Webasto timer/controller for it? Thanks |
15th Jan 2025 1:01pm |
Webasto has a through pump so can be inline and not running. Cheers
16th Jan 2025 11:03am |
Les, what's the rest of the vehicle? Tc, hard top, sw?
Just thinking of buying it when you have finished as you normally sell them pretty quickly.... Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
16th Jan 2025 4:55pm |
TBF the others went due to me getting Divorced and well they had to so I could start over, had this since 2011'ish and my recently last build....... times catching me up and at 61 I'm getting to old to be building, this was why it was mission creep as I only wanted to do it once. This will be a keep and maintain to keep my hand in. Thank you for wanting to buy it and having confidance in my building ability |
16th Jan 2025 8:02pm |
