Home > Technical > Stock TD5 Aircon Improvement
Page 2 of 2 <12
Dr Phibes
Australia
You mean you have the condenser and it abuts the frame? I haven’t got mine yet but think it should be fine mounted in any orientation as it is pressure fed.
The blower is apparently 223cfm, 3 speed. I haven’t got it yet but it doesn’t look like a perfect fit- will have to adapt. Also need to confirm if I need to replace control unit with another one - assume PWM.
https://www.sparesbox.com.au/products/oex-...ded-emx009
Post #1053183 28th Nov 2024 10:47am
Zimblewinder
Australia 2000 Defender 130 2.5 TD HCPU Chawton White
Hi there, not sure how far along you are Dr but found this on Alibaba. Have a look at the first universal unit. It is exactly the same as the AMC kit used in Australia only with a different vent box riveted on the front(could remove and use the original vent set instead). For $260 for the lot it's a steal. There is also another unit in the pictures which has four outlets for plumbing which might also be a good setup for improved venting.
https://www.alibaba.com/product-detail/Uni...68595.html
Post #1053393 29th Nov 2024 11:13pm
Dr Phibes
Australia
I have the condenser and blower. I have confirmed the blower housing is oversize (marginally) and that the OEX motor will fit the original housing. I just need to get the old blower fans off and put on the shafts.
Post #1053403 30th Nov 2024 12:45am
Zimblewinder
Aukland auto air has an EM0922 with a 4600 or 4800rpm rating (according to the label) which is better than the previous one I posted. The motor I originally bought turned up with only a 3800rpm rating which is less than standard (4000) (so cant imagine it with an even wimpier fan in it!!). Im going to try to get one of these NZ ones.
Post #1054776 16th Dec 2024 1:30am
Dr Phibes
Australia
Good luck. I am stuck with a non starting issue so this is on the back burner
Post #1054780 16th Dec 2024 2:14am
Dr Phibes
Australia
Coming back to this. Don’t rush out to buy a CNX413. Given that the inlet pipe (larger one) should be on top, it won’t fit without modifying the frame… I am going to look at options.
Post #1057312 13th Jan 2025 11:03pm
Page 2 of 2 <12
